  • 摄像头运行过程中,画面卡顿怎么解决?希望摄像头在供电的情况下一直识别颜色
      from pyb import Pin
      import math
      threshold_index = 0
      thresholds = [
      	(34, 82, -32, -12, -13, 31),
      sensor.skip_frames(time=2000)
      sensor.set_auto_gain(False)
      pin0 = Pin("P0", Pin.OUT_PP, Pin.PULL_NONE)
      pin1 = Pin("P1", Pin.OUT_PP, Pin.PULL_NONE)
      LED1 = Pin("P2", Pin.OUT_PP, Pin.PULL_NONE)
      LED2 = Pin("P3", Pin.OUT_PP, Pin.PULL_NONE)
      	for blob in img.find_blobs(
      			[thresholds[threshold_index]],
      			pixels_threshold=200,
      			area_threshold=200,
      			merge=True,
      		if blob.elongation() > 0.5:
      			img.draw_edges(blob.min_corners(), color=(255, 0, 0))
      			img.draw_line(blob.major_axis_line(), color=(0, 255, 0))
      			img.draw_line(blob.minor_axis_line(), color=(0, 0, 255))
      			img.draw_keypoints(
      				[(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20
      			pin1.value(1)
      			LED1.value(1)
      			pin0.value(0)
      			LED2.value(0)
      			time.sleep(5)
      	pin1.value(0)
      	LED1.value(0)
      	pin0.value(1)
      	LED2.value(1)
      	time.sleep(5)
    • 把41行和47行的sleep删除就不卡了。
