摄像头运行过程中,画面卡顿怎么解决?希望摄像头在供电的情况下一直识别颜色
import sensor, image, time from pyb import Pin import math threshold_index = 0 thresholds = [ (34, 82, -32, -12, -13, 31), ] sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time=2000) sensor.set_auto_gain(False) sensor.set_auto_whitebal(False) clock = time.clock() pin0 = Pin("P0", Pin.OUT_PP, Pin.PULL_NONE) pin1 = Pin("P1", Pin.OUT_PP, Pin.PULL_NONE) LED1 = Pin("P2", Pin.OUT_PP, Pin.PULL_NONE) LED2 = Pin("P3", Pin.OUT_PP, Pin.PULL_NONE) while True: clock.tick() img = sensor.snapshot() for blob in img.find_blobs( [thresholds[threshold_index]], pixels_threshold=200, area_threshold=200, merge=True, ): if blob.elongation() > 0.5: img.draw_edges(blob.min_corners(), color=(255, 0, 0)) img.draw_line(blob.major_axis_line(), color=(0, 255, 0)) img.draw_line(blob.minor_axis_line(), color=(0, 0, 255)) img.draw_rectangle(blob.rect()) img.draw_cross(blob.cx(), blob.cy()) img.draw_keypoints( [(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20 ) pin1.value(1) LED1.value(1) pin0.value(0) LED2.value(0) time.sleep(5) print(clock.fps()) pin1.value(0) LED1.value(0) pin0.value(1) LED2.value(1) time.sleep(5)
把41行和47行的sleep删除就不卡了。
