如何讲apriltag的六个数值传输的stm32上?后面一部分看不懂不会改?
c_x = 160 * 0.5 # 默认值(image.w * 0.5) c_y = 120 * 0.5 # 默认值(image.h * 0.5)图片位置 def degrees(radians): return (180 * radians) / math.pi#计算弧度 while(True): img = sensor.snapshot() # Take a picture and return the image. for tag in img.find_apriltags(fx=f_x, fy=f_y, cx=c_x, cy=c_y): # 默认为TAG36H11 if blobs: print('sum :', len(apriltag)) output_str = json.dumps(apriltag) for a in apriltag: # Draw a rect around the blob. img.draw_rectangle(a.rect()) # rect img.draw_cross(a.cx(), a.cy()) # cx, cy print('you send:',output_str) uart.write(output_str+'\n') else: print('not found!')
你要先确定好协议,用二进制发送,还是字符串发送,然后生成数据。
