  • openmv与阿里云平台连接,这个错误是为什么,怎么解决
    • import time
      import network
      import usocket as socket
      from mqtt import MQTTClient
      # WiFi连接配置
      WIFI_SSID = "wifi"
      WIFI_PASSWORD = "tttt1234"
      # 阿里云IoT平台MQTT服务器配置
      # 阿里云IoT平台MQTT服务器配置
      ALIYUN_SERVER = "iot-060abets.mqtt.iothub.aliyuncs.com"
      CLIENT_ID = "k0zvw5MlCDl.TC6ICgOHb7cVk3Roy1cN|securemode=2,signmethod=hmacsha256,timestamp=1711519481150|"
      USERNAME = "TC6ICgOHb7cVk3Roy1cN&k0zvw5MlCDl"
      PASSWORD = "4b7b97817bc41a9df9f07af8cccf4b11673f61539907d42339a72af8c4a031e0"
      PORT = 1883
      # WiFi连接
      def connect_wifi():
          wlan = network.WLAN(network.STA_IF)
          wlan.active(True)
          if not wlan.isconnected():
              print("Connecting to WiFi...")
              wlan.connect(WIFI_SSID, WIFI_PASSWORD)
              while not wlan.isconnected():
                  pass
          print("WiFi Connected!")
          print("IP Address:", wlan.ifconfig()[0])
      # MQTT消息回调函数
      def mqtt_callback(topic, msg):
          print("Received message from topic: {}, Message: {}".format(topic, msg))
      # 连接到阿里云IoT平台的MQTT服务器
      def connect_mqtt():
          client = MQTTClient(CLIENT_ID, ALIYUN_SERVER, 1883, USERNAME, PASSWORD)
          client.set_callback(mqtt_callback)
          client.connect()
          print("Connected to Aliyun IoT Platform!")
          return client
      # 订阅主题
      def subscribe_topic(client, topic):
          client.subscribe(topic)
          print("Subscribed to topic:", topic)
      # 发布消息
      def publish_message(client, topic, message):
          client.publish(topic, message)
          print("Published message to topic:", topic)
      def main():
          connect_wifi()
          mqtt_client = connect_mqtt()
          subscribe_topic(mqtt_client, "your_subscribed_topic")
          # 模拟数据,并发布到指定的主题
              data = "Your sensor data"  # 替换成您的传感器数据
              publish_message(mqtt_client, "your_published_topic", data)
              time.sleep(5)  # 每隔5秒发送一次数据
      if __name__ == "__main__":
          main()
    • 看上去你的WiFi不对,没有获取到ip,检查路由器是不是有问题。
      按照这个代码测试一下:
      https://forum.singtown.com/topic/10751/mqtt协议和阿里云平台连接不上/4
