如何通过向OpenMV发送不同的命令获取距离或者是图片?
import sensor, image, time, network, usocket, sys, json from machine import I2C from vl53l1x import VL53L1X import time import gc gc.enable() i2c = I2C(2) distance = VL53L1X(i2c) SSID ='HSAuto' # Network SSID KEY ='Aa123456' # Network key HOST =' 10.119.96.163' # Use first available interface PORT = 8082 # Arbitrary non-privileged port dic = {'Fn':0,'Q':1,'T':2,'L':3,'Space':4,'Up':5,'Down':6,'N':7} sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.VGA) # Set frame size to QVGA (320x240) sensor.skip_frames(time = 2000) sensor.set_auto_whitebal(True) sensor.set_auto_gain(True) #srnsor.set_ #sensor.set_hmirror(True) #水平方向翻转 #sensor.set_vflip(True) #垂直方向翻转 # 二维码的识别img = sensor.snapshot() img_w = 640 img_h = 480 #OV5640 VGA 的像素大小 f_x = (2.8 / 3.6736) * img_w # 默认值 f_y = (2.8 / 2.7384) * img_h # 默认值 #图像的中心位置 分辨率的一半 c_x = img_w * 0.5 # 默认值(image.w * 0.5) c_y = img_h * 0.5 # 默认值(image.h * 0.5) # Init wlan module and connect to network print("Trying to connect... (may take a while)...") wlan = network.WINC() wlan.connect(SSID, key=KEY, security=wlan.WPA_PSK) # We should have a valid IP now via DHCP print(wlan.ifconfig()) # Create server socket s = usocket.socket(usocket.AF_INET, usocket.SOCK_STREAM) # Bind and listen print(HOST) s.bind([HOST, PORT]) s.listen(5) print(s) s.setblocking(True) def start_streaming(s): try: print ('Waiting for connections..') client, addr = s.accept() img_w = 640 * 0.5 img_h = 480 * 0.5 client.settimeout(2.0) print ('Connected to ' + addr[0] + ':' + str(addr[1])) data = client.recv(32) recv_data = str(data,'utf-8') print(recv_data) clock = time.clock() img = sensor.snapshot().lens_corr(0.9) if recv_data == "GetDistance": Camera_Distance = int(distance.read()) - 11 print(Camera_Distance) client.send(str(Camera_Distance)) # +"mm \r\n" elif "GetImage" in recv_data: clock = time.clock() frame = sensor.snapshot() cframe = frame.compressed(quality=35) client.send("HTTP/1.1 200 OK\r\n" \ "Server: OpenMV\r\n" \ "Content-Type: image/jpeg\r\n\r\n" ) print(len(cframe)) client.send(cframe) client.send("END") # client.close() # cframe = img.compressed(quality=40) # client.write(cframe) client.close() client.close() gc.collect() print(gc.mem_free()) except OSError as e: print(e) while (True): try: start_streaming(s) except OSError as e: print("socket error: ", e) sys.print_exception(e)
recv_data是http的请求头,里面可以看到url。如果你访问的是192.168.1.1:8080/distance或者192.168.1.1:8080/image,recv_data是可以看到的。
@kidswong999 不是用Http请求的,是用的Socket通信 TCP 请求的,发完参数,如何返回图片呢,直接 client.send()吗?这个可以实现吗
