  • 求问如何将这种坐标值来传输进32单片机里面进行通信?不使用字典
    • from machine import Pin
      import sensor, image, time,math,pyb
      #import seekfree, pyb
      import pyb
      import ustruct
      laser_light=Pin("P9", Pin.OUT)
      laser_light.value(1)
      #lcd = seekfree.LCD180(3)
      sensor.set_pixformat(sensor.RGB565) # 设置图像色彩格式为RGB565格式
      sensor.set_framesize(sensor.QQVGA) # 设置图像大小为160*120
      sensor.set_auto_whitebal(True) # 设置自动白平衡
      sensor.set_brightness(3000) # 设置亮度为3000
      sensor.skip_frames(time = 20) # 跳过帧
      sensor.set_auto_gain(False)
      corner = 0
      uart = UART(3,115200)
      def sending_data(corner1_str,corner2_str,corner3_str,corner4_str):
      global uart;
      data = ustruct.pack("<bbhhhhb",
      0x2C,
      0x12,
      str(corner1_str),
      str(corner2_str),
      str(corner3_str),
      str(corner4_str),
      0x5B)
      uart.write(data);
      # 在图像中寻找矩形
          # 判断矩形边长是否符合要求
          if r.w() > 20 and r.h() > 20:
              # 在屏幕上框出矩形
              img.draw_rectangle(r.rect(), color = (255, 0, 0), scale = 4)
              # 获取矩形角点位置
              corner = r.corners()
              # 在屏幕上圈出矩形角点
              img.draw_circle(corner[0][0], corner[0][1], 5, color = (0, 0, 255), thickness = 2, fill = False)
              img.draw_circle(corner[1][0], corner[1][1], 5, color = (0, 0, 255), thickness = 2, fill = False)
              img.draw_circle(corner[2][0], corner[2][1], 5, color = (0, 0, 255), thickness = 2, fill = False)
              img.draw_circle(corner[3][0], corner[3][1], 5, color = (0, 0, 255), thickness = 2, fill = False)
              corner4_str = f"corner4 = ({corner[0][0]},{corner[0][1]})"
              corner3_str = f"corner3 = ({corner[1][0]},{corner[1][1]})"
              corner2_str = f"corner2 = ({corner[2][0]},{corner[2][1]})"
              corner1_str = f"corner1 = ({corner[3][0]},{corner[3][1]})"
              data = bytearray([0x2C,0x12,corner1_str,corner2_str,corner3_str,corner4_str,0x5B])
              uart.write(data)
              print(corner1_str + "\n" + corner2_str + "\n" + corner3_str + "\n" + corner4_str)
      # 设置激光颜色阈值
      red_td = [(56, 100, 45, 127, -128, 127)]
      # 根据阈值找到色块
      for b in img.find_blobs(red_td,pixels_threshold=2, area_threshold=15, merge=True,invert = 0):
          # 在屏幕上画出色块
          img.draw_rectangle(b.rect(), color = (0, 255, 0), scale = 2, thickness = 2)
          print(f"rect = {b.x() + b.w()/2},{b.y() + b.h()/2}")
      这里面也要咋去修改呀
    • @shuc求问如何将这种坐标值来传输进32单片机里面进行通信?不使用字典 中说:
      这里面也要咋去修改呀,换成列表list吗
    • 如果你要发送二进制的格式,就不要用字符串了
