  • local variable referenced before assignment,求解
      import sensor, image, time,math,pyb
      from pyb import Servo
      from pyb import UART,LED
      import ustruct
      pan_servo=Servo(1) #定义两个舵机
      tilt_servo=Servo(2)
      red_threshold_01 = ((14, 88, 24, 116, -18, 106));
      bule_threshold_01 = ((16, 65, -20, 35, -64, -21));
      yello_threshold_01 = ((53, 71, -14, 0, -7, 22));
      sensor.set_auto_gain(False) # 关闭自动增益
      sensor.set_auto_whitebal(False) # turn this off.关闭白平衡
      #sensor.set_vflip(True)#垂直方向翻转
      uart = UART(3,115200)
      def sending_data(flag):
          global uart;
          data = ustruct.pack("<bbhb",
                         0x2C,
                         0x12,
                         int(flag),
                         0x5B)
          uart.write(data);
              flag = None
              blobs = img.find_blobs([red_threshold_01], pixels_threshold=100, area_threshold=100, merge=True, margin=10);      #红色物块
              blobs1 = img.find_blobs([bule_threshold_01], pixels_threshold=100, area_threshold=100, merge=True, margin=10); #绿色物块
              blobs2 = img.find_blobs([yello_threshold_01], pixels_threshold=100, area_threshold=100, merge=True, margin=10);   #黄色物块
                  max_blob = find_max(blobs)#判断最大的色块为哪一个
                  #如果找到了目标颜色
                  print("red")
                  flag = 1
                  for b in blobs:
                  #迭代找到的目标颜色区域
                      img.draw_rectangle(max_blob.rect())#img.draw_rectangle(b[0:4]) # rect
                      #用矩形标记出目标颜色区域
                      img.draw_cross(max_blob.cx(), max_blob.cy())#img.draw_cross(b[5], b[6]) # cx, cy
                      #在目标颜色区域的中心画十字形标记
                      data = bytearray([0x2C,0x12,flag,0x5B])
                      uart.write(data)
                 # img.draw_rectangle(max_blob.rect()) # rect,框选起来
                 # img.draw_cross(max_blob.cx(), max_blob.cy()) # cx, cy,框选起来
                  pan_servo.angle(pan_servo.angle()+pan_output)#控制舵机转动的角度
              elif blobs1:
                  #如果找到了目标颜色
                  print("bule")
                  flag = 2
                  for b in blobs1:
                  #迭代找到的目标颜色区域
                      #用矩形标记出目标颜色区域
                      #在目标颜色区域的中心画十字形标记
                      uart.write(data)
              elif blobs2:
                  #如果找到了目标颜色
                  print("yello")
                  flag = 1
                  for b in blobs2:
                  #迭代找到的目标颜色区域
                      #用矩形标记出目标颜色区域
                      #在目标颜色区域的中心画十字形标记
                      uart.write(data)
    • 92行应该是blobs1而不是blobs.
      120行应该是blobs2而不是blobs.
