  • openmv串口数据输出问题
    • 输出值有的时候比打印出来的数据少6
      下面是串口助手收到的数据
      下面是openmv源码
      请问是哪里出了问题?
    • This post is deleted!
    • @kidswong999
      没有报错,是输出数据与打印数据有差异
    • @kidswong999
      from pyb import UART,LED
      import ustruct
      #white_threshold_01 = ((95, 100, -18, 3, -8, 4)); #白色阈值
      red_threshold_01 = ((17, 67, 23, 71, -1, 45));
      red_led =LED(1)
      green_led =LED(2)
      blue_led=LED(3)
      uart = UART(3,500000) #定义串口3变量
      uart.init(500000, bits=8, parity=None, stop=1) # init with given parameters
      def find_max(blobs): #定义寻找色块面积最大的函数
      if blob.pixels() > max_size:
      max_size = blob.pixels()
      def USART_SendData(fx,dx,fy,dy):
      global uart;
      #data = bytearray(frame)
      data = ustruct.pack("<bbhhhhb", #格式为俩个字符俩个短整型(2字节)
      0xFF, #帧头
      0xFE,
      int(fx), # up sample by 4 #数据1
      int(dx),
      int(fy), # up sample by 4 #数据2
      int(dy),
      0xFD)
      uart.write(data); #必须要传入一个字节数组
      def recive_data():
      global uart
      if uart.any():
      tmp_data = uart.readline();
      print(tmp_data)
      #mainloop
      # pixels_threshold=100, area_threshold=100
      blobs = img.find_blobs([red_threshold_01], area_threshold=150);
      cx=0;cy=0;
          #如果找到了目标颜色
          max_b = find_max(blobs);
          img.draw_rectangle(max_b[0:4]) # rect
          #用矩形标记出目标颜色区域
          img.draw_cross(max_b[5], max_b[6]) # cx, cy
          img.draw_cross(160, 120) # 在中心点画标记
          #在目标颜色区域的中心画十字形标记
          cx=max_b[5];
          cy=max_b[6];
          img.draw_line((160,120,cx,cy), color=(127));
          #img.draw_string(160,120, "(%d, %d)"%(160,120), color=(127));
          img.draw_string(cx, cy, "(%d, %d)"%(cx,cy), color=(127));
          fx=cx//10
          fy=cy//10
          dx=fx/10
          dy=fy/10
          USART_SendData(fx,dx,fy,dy) #发送点位坐
          print('整数:%d '%fx,'余数:%d '%dx,'整数:%d '%fy,'余数:%d '%dy);
          time.sleep(5);
          recive_data();
          blue_led.off()
          red_led.off()
          green_led.on()
          blue_led.off()
          green_led.off()
          red_led.on()
          if uart.any():
              blue_led.on()
              green_led.off()
              red_led.off()
