结合跟踪及模板匹配跑的代码报错?
import sensor, image, time ,math ,struct from pyb import UART from struct import pack, unpack import json from image import SEARCH_EX, SEARCH_DS red_threshold =(8, 95, 29, 79, 12, 68)#(9, 90, 52, 79, 12, 68)#(7, 90, 12, 70, -6, 41)#(15, 100, 40, 100, 40, 80)#(100, 27, 28, 111, 94, -59) sensor.reset() sensor.set_pixformat(sensor.GRAYSCALE) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time=3000) sensor.set_auto_whitebal(False) clock = time.clock() uart = UART(1, 115200) template = image.Image("/0.pgm") def find_max(blobs): max_size=1 if blobs: max_blob = 0 for blob in blobs: blob_size = blob.w()*blob.h() if ( (blob_size > max_size) & (blob_size > 100) & (blob.density()>0.8*math.pi/4) & (blob.density()<1.2*math.pi/4) ) : if ( math.fabs( blob.w() / blob.h() - 1 ) < 0.5 ) : max_blob=blob max_size = blob.w()*blob.h() return max_blob def find_red(blobs): max_size = 0 for blob in blobs: if blob[2]*blob[3] > max_size: max_blob=blob max_size = blob[2]*blob[3] return max_size def line_filter_copy(src, dst): for i in range(0, len(dst), 1): dst[i] = src[i<<1] def line_filter_bw(src, dst): for i in range(0, len(dst), 1): if (src[i<<1] > 200 and src[i<<1] < 255): dst[i] = 0xFF else: dst[i] = 0x00 k = 0 max_number = 0 a = 0 b = 0 min_yellow = 0 tmp_data = 0 while(True): clock.tick() lines = 0 img = sensor.snapshot(line_filter = line_filter_copy) red_blobs = img.find_template(template, 0.70, step=4, search=SEARCH_EX) max_blob=find_max(red_blobs) last_x = 1000 last_y = 1000 if max_blob: img.draw_rectangle(max_blob.rect()) img.draw_cross(max_blob.cx(), max_blob.cy()) bx_x=max_blob.cx()-160 by_y=120-max_blob.cy() x=math.fabs(bx_x) y=math.fabs(by_y) if 0 <= x < 10 : bx_value = 1 elif 10 <= x < 100 : bx_value = 2 else : bx_value = 3 if 0 <= y < 10 : by_value = 1 elif 10 <= y < 100 : by_value = 2 else : by_value = 3 sumA = 0 sumB = 0 data = bytearray([0x41,0x43]) uart.write(data) data = bytearray([0x02,8]) for b in data: sumB = sumB + b sumA = sumA + sumB uart.write(data) float_value = bx_x float_bytes = pack('f', float_value) for b in float_bytes: sumB = sumB + b sumA = sumA + sumB uart.write(float_bytes) float_value = by_y float_bytes = pack('f', float_value) for b in float_bytes: sumB = sumB + b sumA = sumA + sumB uart.write(float_bytes) data = bytearray([sumB, sumA]) uart.write(data) print("found: x=",bx_x," y=",by_y) #b_output_str="x%d%d,y%d%d" % (bx_value,bx_x,by_value,by_y) #print('you send black:',b_output_str) #uart.write(b_output_str+'\r\n') else: sumA = 0 sumB = 0 data = bytearray([0x41,0x43]) uart.write(data) data = bytearray([0x01,0]) for b in data: sumB = sumB + b sumA = sumA + sumB uart.write(data) data = bytearray([sumB, sumA]) uart.write(data) print(sumA," ",sumB) #print('not found!') #b_output_str = "x10,y10" #print('you send black:',b_output_str) #b_output_str = "x3750,y3750" #uart.write(b_output_str+'\r\n') #pass
find_template只会返回一个结果,不能find_max
