  • can't convert str to int,咋解决呀?
    • import sensor, image, time,math,pyb
      from pyb import UART,LED
      import ustruct
      sensor.set_auto_gain(False)
      red_threshold_01=(10, 100, 127, 32, -43, 67)
      uart = UART(3,115200)
              if blob.pixels() > max_size:
                  max_size = blob.pixels()
      def sending_data(flag):
          global uart;
          data = ustruct.pack("<bbhb",
                         0x2C,
                         0x12,
                         str(flag),
                         0x5B)
          uart.write(data);
          flag = 0
          blobs = img.find_blobs([red_threshold_01])
          cx=0;cy=0;
                  max_b = find_max(blobs)
                  cx=max_b[5]
                  cy=max_b[6]
                  cw=max_b[2]
                  ch=max_b[3]
                  flag = "red"
                  img.draw_rectangle(max_b[0:4])
                  img.draw_cross(max_b[5], max_b[6])
                  FH = bytearray([0x2C,0x12,str(flag),0x5B])
                  uart.write(FH)
                  print(flag)
    • This post is deleted!
    • 你怎么能把"red"字符串当成bytearray发送呢?
    • @kidswong999 l佬,我的想法是发送出去这个red字符串,那该去怎么改呀?
    • @kidswong999 openmv与stm32通信识别到色块之后发送red这个字符串
    • 既然发送字符串,又加0x2c, 0x12,0x5b做什么呢?你把设备的协议文档发上来。
