  • 如何解决错误,用得openmv训练的数据集进行数字识别
    • import sensor, image, time, os, tf, math, uos, gc
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
      counter = [0,0,0,0,0,0,0,0,0,0,0]
          clock.tick()  # 记录当前时间
          img = sensor.snapshot()  # 获取图像帧
          detections = net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)])
          for obj in detections:
              label = labels[obj.classid()]
              confidence = obj.confidence()
              if confidence > min_confidence:
                  counter[label] += 1
              if counter[label] > 10:
                  counter[label] = 0
                  print("%s" % labels[label])
                  [x, y, w, h] = obj.rect()
                  img.draw_circle((center_x, center_y), 12, color=colors[i], thickness=2)
                  img.draw_string(center_x + 20, center_y + 20, labels[i], color=colors[i], scale=1)
    • 你的代码和配套生成的代码不一样啊。
