  • 请问怎么设置每隔10s清除一下全局变量的数据
    • 请问怎么设置每10s清除一下全局变量的数据,也就是我的List_score01,我使用定时器会报错
      import sensor, image, time, os, tf, uos, gc, lcd , cpufreq
      from pyb import UART,LED,Timer
      uart = UART(3, 115200, timeout_char=1000)
      u_start=bytearray([0x2C,0x12])
      u_over=bytearray([0x5B])
      LED(2).on()
      sensor.set_framesize(sensor.QQVGA)     # Set frame size to QVGA (320x240)
      #sensor.skip_frames(time=2000)          # Let the camera adjust.
      lcd.init()
      net = None
      labels = None
      List_score01 = [0]*7
      flag = 0
      except Exception as e:
          print(e)
      flag_stop = 0
      number = 1
      #label = "in","line","out","stop","wandao1","wandao2","word"
      #label = "0" ,"1"   ,"2"  ,"3"   ,"4"      ,"5"      ,"6"
      #def test(timer):
          #global List_score01
          #List_score01 = [0]*7
          #print("11111111")
      #tim = Timer(2, freq=1)      # 使用定时器2创建定时器对象-以1Hz触发
      #tim.callback(test)          # 将回调设置为tick函数
      def problem_1(predictions_list):
          global flag_stop
          global List_score01
          uart.write(u_start)
          uart.write(bytearray([3]))
          uart.write(u_over)
          print("problem_1 was OK")
          if(predictions_list[3][1]>=0.4): #'stop'
              print(List_score01)
              flag_stop +=1
              LED(3).on()
              #print(flag_stop)
              while flag_stop >=2:
                  number = 1
                  while number < 5:  #发送"5"
                      uart.write(u_start)
                      uart.write(bytearray([5]))
                      uart.write(u_over)
                      print(5)
                      number +=1
                      time.sleep_ms(100)
                  flag_stop=0
                  number = 1
              time.sleep_ms(1000)
              LED(3).off()
      def problem_3(predictions_list):
          number3=1
          global List_score01
          uart.write(u_start)
          uart.write(u_over)
          if(predictions_list[0][1]>=0.4): #'in'
              List_score01[int(predictions_list[0][0])] += 1
              #print(List_score01)
              if List_score01[0]>1:
                  while number3 < 5:  #发送10个"2"
                      uart.write(u_start)
                      uart.write(bytearray([2]))
                      uart.write(u_over)
                      number3 +=1
                      time.sleep_ms(100)
                  number3 = 1  #number清除再发送"3"
                  while number3 < 10:  #发送"3"
                      uart.write(u_start)
                      uart.write(u_over)
                      #print(3)
                      number3 +=1
                      time.sleep_ms(100)
                  List_score01 = [0]*7    #退出初始化循环
          cpufreq.set_frequency(480)
          img = sensor.snapshot().lens_corr(strength = 1.6, zoom = 1.0)
              #for i in range(len(predictions_list)):
                  #print("%s = %f" % (predictions_list[i][0], predictions_list[i][1]))
          if uart.any():   ##收到单片机发送来的数据
              a=uart.readline().decode()
              if(a[0]=='1'):
                  flag = 1
              if(a[0]=='3'):
                  flag = 3
          if flag == 1:
          if flag == 3:
          print(clock.fps(), "fps")
          lcd.display(img)
    • 定时清除全局变量的思路不正常。我也看不懂你的problem_1,problem_3是个啥。
