  • 全局变量报错,错误为SyntaxError: identifier redefined as global
    • import sensor, image, time, os, tf, uos, gc, lcd , cpufreq
      from pyb import UART,LED,Timer
      uart = UART(3, 115200, timeout_char=1000)
      u_start=bytearray([0x2C,0x12])
      u_over=bytearray([0x5B])
      LED(2).on()
      sensor.set_framesize(sensor.QQVGA)     # Set frame size to QVGA (320x240)
      #sensor.skip_frames(time=2000)          # Let the camera adjust.
      lcd.init()
      net = None
      labels = None
      List_score01 = [0]*7
      #global List_score01
      except Exception as e:
          print(e)
      #label = "in","line","out","stop","wandao1","wandao2","word"
      #label = "0" ,"1"   ,"2"  ,"3"   ,"4"      ,"5"      ,"6"
          #flag=3
          number = 1
          cpufreq.set_frequency(480)
          img = sensor.snapshot().lens_corr(strength = 1.6, zoom = 1.0)
          global List_score01
              #print(obj.output())
              #print(predictions_list)
              #print(predictions_list[0][1])
              print(List_score01)
              if(predictions_list[0][1]>=0.7): #'in'
                  List_score01[int(predictions_list[0][0])] += 1
                  print(List_score01)
                  if List_score01[0]>1:
                      while number < 5:  #发送10个"2"
                          uart.write(u_start)
                          uart.write(bytearray([2]))
                          uart.write(u_over)
                          #img.draw_string(0, 0, "flag:%s" %(flag), scale=2, color=(255, 0, 0))
                          print(2)
                          number +=1
                          time.sleep_ms(100)
                      number = 1  #number清除再发送"3"
                      while number < 10:  #发送"3"
                          uart.write(u_start)
                          uart.write(bytearray([3]))
                          uart.write(u_over)
                          print(3)
                          number +=1
                          time.sleep_ms(100)
                      List_score01 = [0]*7    #退出初始化循环
              if(predictions_list[3][1]>=0.9): #'stop'
                  List_score01[int(predictions_list[3][0])] += 1
                  #print(List_score01)
                  if List_score01[3]>20:
                      while number < 7:  #发送"2"
                          uart.write(u_start)
                          uart.write(bytearray([5]))
                          uart.write(u_over)
                          print(5)
                          number +=1
                          time.sleep_ms(100)
          #img.draw_string(10,10,str(flag),color=(0,0,255))
          uart_buf = bytearray([3])
          uart.write(u_start)
          uart.write(uart_buf)
          uart.write(u_over)
          #print(clock.fps(), "fps")
          lcd.display(img)
      def test(timer):
          global List_score01
          print("11111111")
      tim = Timer(4, freq=1)      # 使用定时器2创建定时器对象-以1Hz触发
      tim.callback(test)          # 将回调设置为tick函数
      主函数中global List_score01报错
    • while True不是函数,不需要加global
