  • 系统报错大师指点怎么处理?
    • 0_1554801749788_2a8ce14e75fccb30b0401cb9c829ab4.jpg0_1554802128599_dd1f5a4d9cfe9a69c57d28eba79ec0d.jpg 0_1554802172327_d5147ccc1fba8badc7df2b0fa864de0.jpg from pyb import Pin, Timer
      inverse_left=False #change it to True to inverse left wheel
      ain1 = Pin('P0', Pin.OUT_PP)
      ain2 = Pin('P1', Pin.OUT_PP)
      bin1 = Pin('P2', Pin.OUT_PP)
      bin2 = Pin('P3', Pin.OUT_PP)
      ain1.low()
      ain2.low()
      bin1.low()
      bin2.low()
      pwma = Pin('P7')
      pwmb = Pin('P8')
      tim = Timer(4, freq=1000)
      ch1.pulse_width_percent(0)
      ch2.pulse_width_percent(0)
      if inverse_left==True:
      left_speed=(-left_speed)
      if inverse_right==True:
      right_speed=(-right_speed)
      if left_speed < 0:
          ain1.low()
          ain2.high()
          ain1.high()
          ain2.low()
      ch1.pulse_width_percent(abs(left_speed))
      import car
          car.run(100,100)
      请在这里粘贴代码
    • https://singtown.com/learn/49239/
      按照视频操作。
