  • OpenMV 模块与自己的电机驱动相连,一通电模块上白灯一直闪。
    • 模块上面引脚连接好电机驱动口后,电机一动一停
      car.py
      from pyb import Pin, Timer
      inverse_left=False  #change it to True to inverse left wheel
      ain1 =  Pin('P0', Pin.OUT_PP)
      ain2 =  Pin('P1', Pin.OUT_PP)
      bin1 =  Pin('P2', Pin.OUT_PP)
      bin2 =  Pin('P3', Pin.OUT_PP)
      ain1.low()
      ain2.low()
      bin1.low()
      bin2.low()
      pwma = Pin('P7')
      pwmb = Pin('P8')
      tim = Timer(4, freq=1000)
      ch1.pulse_width_percent(0)
      ch2.pulse_width_percent(0)
          if inverse_left==True:
              left_speed=(-left_speed)
          if inverse_right==True:
              right_speed=(-right_speed)
          if left_speed < 0:
              ain1.low()
              ain2.high()
              ain1.high()
              ain2.low()
          ch1.pulse_width_percent(abs(left_speed))
          if right_speed < 0:
              bin1.low()
              bin2.high()
              bin1.high()
              bin2.low()
          ch2.pulse_width_percent(abs(right_speed))
      pid.py
      from pyb import millis
      from math import pi, isnan
      class PID:
      _kp = _ki = _kd = _integrator = _imax = 0
      _last_error = _last_derivative = _last_t = 0
      _RC = 1/(2 * pi * 20)
      def init(self, p=0, i=0, d=0, imax=0):
      self._kp = float(p)
      self._ki = float(i)
      self._kd = float(d)
      self._imax = abs(imax)
      self._last_derivative = float('nan')
      def get_pid(self, error, scaler):
          tnow = millis()
          dt = tnow - self._last_t
          output = 0
          if self._last_t == 0 or dt > 1000:
              dt = 0
              self.reset_I()
          self._last_t = tnow
          delta_time = float(dt) / float(1000)
          output += error * self._kp
          if abs(self._kd) > 0 and dt > 0:
              if isnan(self._last_derivative):
                  derivative = 0
                  self._last_derivative = 0
                  derivative = (error - self._last_error) / delta_time
              derivative = self._last_derivative + \
                                       ((delta_time / (self._RC + delta_time)) * \
                                          (derivative - self._last_derivative))
              self._last_error = error
              self._last_derivative = derivative
              output += self._kd * derivative
          output *= scaler
          if abs(self._ki) > 0 and dt > 0:
              self._integrator += (error * self._ki) * scaler * delta_time
              if self._integrator < -self._imax: self._integrator = -self._imax
              elif self._integrator > self._imax: self._integrator = self._imax
              output += self._integrator
          return output
      def reset_I(self):
          self._integrator = 0
      Blob Detection Example
      This example shows off how to use the find_blobs function to find color
      blobs in the image. This example in particular looks for dark green objects.
      import car
      You may need to tweak the above settings for tracking green things...
      Select an area in the Framebuffer to copy the color settings.
      For color tracking to work really well you should ideally be in a very, very,
      very, controlled enviroment where the lighting is constant...
      green_threshold = (76, 96, -110, -30, 8, 66)
      size_threshold = 2000
      x_pid = PID(p=0.5, i=1, imax=100)
      h_pid = PID(p=0.05, i=0.1, imax=50)
          max_blob = find_max(blobs)
          x_error = max_blob[5]-img.width()/2
          h_error = max_blob[2]*max_blob[3]-size_threshold
          print("x error: ", x_error)
          for b in blobs:
          img.draw_rectangle(max_blob[0:4]) # rect
          img.draw_cross(max_blob[5], max_blob[6]) # cx, cy
          x_output=x_pid.get_pid(x_error,1)
          h_output=h_pid.get_pid(h_error,1)
          print("h_output",h_output)
          car.run(-h_output-x_output,-h_output+x_output)
          car.run(10,-10)
    • 我们只能保证我们的程序,和我们的教程里的结构是匹配的。
      首先,电机驱动和连线要是一样的,tb6612。
      小车的连线方式,教程里也有说。
      其他结构的小车,每个人的都不一样,我们没办法手把手的给每个小车,都写一遍代码。
    • 0_1535965611058_亚博智能TB6612.png 0_1535965622198_星瞳所用TB6612.png 两种电机驱动一模一样,电平也是一致的,接口也都接对了。
      为什么还是会一闪一闪的重启模块呢?
    • 我估计你的电源接的,不对。
      如果电源接错了,OpenMV很容易损坏。
      tb6612的VM引脚,应该接OpenMV的VIN引脚。千万不能接OpenMV的3.3V引脚。
