云台输出的角度是什么意思
print("pan_output",pan_output) pan_servo.angle(pan_servo.angle()+pan_output) tilt_servo.angle(tilt_servo.angle()-tilt_output)
@kidwong999 你好,我们想知道的是后面打印的
pan_output"这个输出的这个是什么意思
是pid的输出。
OpenMV视觉算出来一个误差,也就是pan_err,作为反馈,输入到pid,得到pan_output,然后用pan_output控制舵机。
@kidswong999 可以控制云台360度旋转吗
星瞳科技的云台,舵机是180度
img.draw_rectangle(max_blob.rect()) # rect img.draw_cross(max_blob.cx(), max_blob.cy()) # cx, cy pan_output=pan_pid.get_pid(pan_error,1)/2 tilt_output=tilt_pid.get_pid(tilt_error,1)
我们想利用串口输出 pan_output,请问怎样才能实现
import sensor, image, time, pyb from pid import PID from pyb import Servo,UART pan_servo=Servo(1) tilt_servo=Servo(2) red_threshold = (13, 49, 18, 61, 6, 47) pan_pid = PID(p=0.07, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID tilt_pid = PID(p=0.05, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID #pan_pid = PID(p=0.1, i=0, imax=90)#在线调试使用这个PID #tilt_pid = PID(p=0.1, i=0, imax=90)#在线调试使用这个PID sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.RGB565) # use RGB565. sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed. sensor.skip_frames(10) # Let new settings take affect. sensor.set_auto_exposure(False, 100)#这里设置曝光时间 sensor.set_auto_whitebal(False) # turn this off. sensor.set_hmirror(True) #水平方向翻转 sensor.set_vflip(True) #垂直方向翻转 clock = time.clock() # Tracks FPS. pan_servo.angle(0) tilt_servo.angle(-20) def find_max(blobs): max_size=0 for blob in blobs: if blob[2]*blob[3] > max_size: max_blob=blob max_size = blob[2]*blob[3] return max_blob while(True): clock.tick() # Track elapsed milliseconds between snapshots(). img = sensor.snapshot() # Take a picture and return the image. blobs = img.find_blobs([red_threshold]) #pan_servo.angle(0) #tilt_servo.angle(0) for i in range(-90,90): img = sensor.snapshot() # pan_servo.angle(i,50) if blobs: pan_servo.speed(0,0) tilt_servo.speed(0,0) max_blob = find_max(blobs) pan_error = max_blob.cx()-img.width()/2 tilt_error = max_blob.cy()-img.height()/2 print("pan_error: ", pan_error) img.draw_rectangle(max_blob.rect()) # rect img.draw_cross(max_blob.cx(), max_blob.cy()) # cx, cy pan_output=pan_pid.get_pid(pan_error,1)/2 tilt_output=tilt_pid.get_pid(tilt_error,1) =float_dumps(set(pan_output)) uart_writefloat(pan_out +'\n') print("pan_output",pan_output) pan_servo.angle(pan_servo.angle()+pan_output) tilt_servo.angle(tilt_servo.angle()-tilt_output) pan_servo.angle(i,100)
麻烦帮忙看下,怎样才能利用串口uart输出pan_output的 坐标
看我上面的回复
