  • 这里缩进为什么会有问题
    • 此回复已被删除!
      # This work is licensed under the MIT license.
      # Copyright (c) 2013-2023 OpenMV LLC. All rights reserved.
      # https://github.com/openmv/openmv/blob/master/LICENSE
      # Template Matching Example - Normalized Cross Correlation (NCC)
      # image patches to parts of an image... expect for extremely controlled environments
      # NCC is not all to useful.
      # a lot of work to be made into somethin useful. This script will remain to show
      import sensor
      import image
      from image import SEARCH_EX
      # from image import SEARCH_DS
      uart=UART(3,9600)
      # Reset sensor
      # Set sensor settings
      # sensor.set_windowing(((640-80)//2, (480-60)//2, 80, 60))
      # Load template.
      template1 = image.Image("/1.pgm")
      template2 = image.Image("/2.pgm")
      template3 = image.Image("/3.pgm")
      template4 = image.Image("/4.pgm")
      template5 = image.Image("/5.pgm")
      template6 = image.Image("/6.pgm")
      template7 = image.Image("/7.pgm")
      template8 = image.Image("/8.pgm")
      # Run template matching
          num=0
          r1 = img.find_template(
              template1, 0.70, step=4, search=SEARCH_EX
          )  # , roi=(10, 0, 60, 60))
          if r1:
              img.draw_rectangle(r1)
              num=1
          r2 = img.find_template(
              template2, 0.70, step=4, search=SEARCH_EX
          if r2:
              img.draw_rectangle(r2)
              num=2
          r3 = img.find_template(
              template3, 0.70, step=4, search=SEARCH_EX
          if r3:
              img.draw_rectangle(r3)
              num=3
          r4 = img.find_template(
              template4, 0.70, step=4, search=SEARCH_EX
          if r4:
              img.draw_rectangle(r)
              num=4
          r5 = img.find_template(
              template5, 0.70, step=4, search=SEARCH_EX
          if r5:
              img.draw_rectangle(r5)
              num=5
          r6 = img.find_template(
              template6, 0.70, step=4, search=SEARCH_EX
          if r6:
              img.draw_rectangle(r6)
              num=6
          r7 = img.find_template(
              template7, 0.70, step=4, search=SEARCH_EX
          if r7:
              img.draw_rectangle(r7)
              num=7
          r8 = img.find_template(
               template8, 0.70, step=4, search=SEARCH_EX
          if r8:
              img.draw_rectangle(r8)
              num=8
      if num!=0 :
              img=sensor.snapshot()
              if num==1:
                  print("1")
                  uart.write("@L\r\n")
              if num==2:
                  print("2")
                  uart.write("@R\r\n")
              if num==3:
                      template3, 0.70, step=4, search=SEARCH_EX )
                  if r3:
                      if r3[0]<80:
              if num==4:
                  if r4:
                      if r4[0]<80:
                      else :
              if num==5:
                  if r5:
                      if r3[0]<80:
              if num==6:
                  if r6:
                      if r6[0]<80:
                      else :
              if num==7:
                  if r7:
                      if r7[0]<80:
                      else :
              if num==8:
                  if r8:
                      if r8[0]<80:
                      else :
    • @kidswong999 咋不回消息嘞
    • 最后一行是5个空格
