  • 为什么显示我错误,求大神解答?
      # image patches to parts of an image... expect for extremely controlled environments
      # NCC is not all to useful.
      # a lot of work to be made into somethin useful. This script will remain to show
      import sensor
      import image
      from image import SEARCH_EX
      # from image import SEARCH_DS
      # Reset sensor
      # Set sensor settings
      # sensor.set_windowing(((640-80)//2, (480-60)//2, 80, 60))
      # Load template.
      templates=["/1.pgm","/2.pgm","/3.pgm","/4.pgm","/5.pgm","/6.pgm","/7.pgm","/8.pgm","/9.pgm","/0.pgm"]
      template1 = image.Image("/1.pgm")
      template2 = image.Image("/2.pgm")
      template3 = image.Image("/3.pgm")
      template4 = image.Image("/4.pgm")
      template5 = image.Image("/5.pgm")
      template6 = image.Image("/6.pgm")
      template7 = image.Image("/7.pgm")
      template8 = image.Image("/8.pgm")
      template9 = image.Image("/9.pgm")
      template0 = image.Image("/0.pgm")
      # Run template matching
          r1 = img.find_template(template, 0.70, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
          if r:
              img.draw_rectangle(r1)
          r2 = img.find_template(template, 0.70, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
          if r:
              img.draw_rectangle(r2)
          r3 = img.find_template(template, 0.70, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
          if r:
              img.draw_rectangle(r3)
          r4 = img.find_template(template, 0.70, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
          if r:
              img.draw_rectangle(r4)
          r5 = img.find_template(template, 0.70, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
          if r:
              img.draw_rectangle(r5)
          r6 = img.find_template(template, 0.70, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
          if r:
              img.draw_rectangle(r6)
          r7 = img.find_template(template, 0.70, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
          if r:
              img.draw_rectangle(r7)
          r8 = img.find_template(template, 0.70, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
          if r:
              img.draw_rectangle(r8)
          r9 = img.find_template(template, 0.70, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
          if r:
              img.draw_rectangle(r9)
          r0 = img.find_template(template, 0.70, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
          if r:
              img.draw_rectangle(r0)
      请在这里粘贴代码
    • 你没有把模板图片放到OpenMV的磁盘里。
      另外多模板匹配用这个代码:
      https://book.openmv.cc/image/mulity-template-match.html
      放进去了还是显示could not find the file
    • @kidswong999 我如果想同时识别出来多个数字应该怎么解决呢
