为什么显示我错误,求大神解答?
# # This example shows off how to use the NCC feature of your OpenMV Cam to match # image patches to parts of an image... expect for extremely controlled environments # NCC is not all to useful. # # WARNING: NCC supports needs to be reworked! As of right now this feature needs # a lot of work to be made into somethin useful. This script will remain to show # that the functionality exists, but, in its current state is inadequate. import time import sensor import image from image import SEARCH_EX # from image import SEARCH_DS # Reset sensor sensor.reset() # Set sensor settings sensor.set_contrast(1) sensor.set_gainceiling(16) # Max resolution for template matching with SEARCH_EX is QQVGA sensor.set_framesize(sensor.QQVGA) # You can set windowing to reduce the search image. # sensor.set_windowing(((640-80)//2, (480-60)//2, 80, 60)) sensor.set_pixformat(sensor.GRAYSCALE) # Load template. # Template should be a small (eg. 32x32 pixels) grayscale image. templates=["/1.pgm","/2.pgm","/3.pgm","/4.pgm","/5.pgm","/6.pgm","/7.pgm","/8.pgm","/9.pgm","/0.pgm"] template1 = image.Image("/1.pgm") template2 = image.Image("/2.pgm") template3 = image.Image("/3.pgm") template4 = image.Image("/4.pgm") template5 = image.Image("/5.pgm") template6 = image.Image("/6.pgm") template7 = image.Image("/7.pgm") template8 = image.Image("/8.pgm") template9 = image.Image("/9.pgm") template0 = image.Image("/0.pgm") clock = time.clock() # Run template matching while True: clock.tick() img = sensor.snapshot() # find_template(template, threshold, [roi, step, search]) # ROI: The region of interest tuple (x, y, w, h). # Step: The loop step used (y+=step, x+=step) use a bigger step to make it faster. # Search is either image.SEARCH_EX for exhaustive search or image.SEARCH_DS for diamond search # # Note1: ROI has to be smaller than the image and bigger than the template. # Note2: In diamond search, step and ROI are both ignored. r1 = img.find_template(template, 0.70, step=4, search=SEARCH_EX) # , roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r1) r2 = img.find_template(template, 0.70, step=4, search=SEARCH_EX) # , roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r2) r3 = img.find_template(template, 0.70, step=4, search=SEARCH_EX) # , roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r3) r4 = img.find_template(template, 0.70, step=4, search=SEARCH_EX) # , roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r4) r5 = img.find_template(template, 0.70, step=4, search=SEARCH_EX) # , roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r5) r6 = img.find_template(template, 0.70, step=4, search=SEARCH_EX) # , roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r6) r7 = img.find_template(template, 0.70, step=4, search=SEARCH_EX) # , roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r7) r8 = img.find_template(template, 0.70, step=4, search=SEARCH_EX) # , roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r8) r9 = img.find_template(template, 0.70, step=4, search=SEARCH_EX) # , roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r9) r0 = img.find_template(template, 0.70, step=4, search=SEARCH_EX) # , roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r0) print(clock.fps()) 请在这里粘贴代码
你没有把模板图片放到OpenMV的磁盘里。
另外多模板匹配用这个代码:
https://book.openmv.cc/image/mulity-template-match.html
放进去了还是显示could not find the file
@kidswong999 我如果想同时识别出来多个数字应该怎么解决呢
