  • edge impluse中我想训练一个“transfer learning"的模型,但是系统提示报错?应该如何解决?
    • edge impluse中我想训练一个“transfer learning"的模型,但是系统提示报错”Failed to start job: Your labeling method is set to "Bounding boxes (Object detection)", but you're trying to train a non-object detection model. Either change the labeling method (on Dashboard), or remove this learn block and add an 'Object detection' block under Create impulse.
      Job failed (see above)“应该怎么解决?
    • 你先确定好你要用分类模型,还是目标检测模型?
