  • "return" outside function,求解
    • import sensor, image, time
      from pyb import Servo
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      pan_servo.calibration(500,2500,500)
      tilt_servo.calibration(500,2500,500)
      red_threshold  = (13, 49, 18, 61, 6, 47)
      sensor.set_auto_gain(False)
      sensor.set_pixformat(sensor.GRAYSCALE) # or sensor.RGB565
      sensor.set_framesize(sensor.  QVGA) # or sensor.QVGA (or others)
      sensor.skip_frames(time=900) # Let new settings take affect.
      sensor.set_auto_exposure(False, 1000)#在这里调节曝光度,调节完可以比较清晰地看清激光点
      sensor.set_auto_gain(False) # 关闭增益(色块识别时必须要关)
          blobs = img.find_blobs(threshold,x_stride=1, y_stride=1, area_threshold=0, pixels_threshold=0,merge=False,margin=1)
          if len(blobs)>=1 :#有色块
              b = blobs[0]
              #img.draw_rectangle(b[0:4]) # rect
              cx = b[5]
              cy = b[6]
              for i in range(len(blobs)-1):
                  cx = blobs[i][5]+cx
                  cy = blobs[i][6]+cy
              cx=int(cx/len(blobs))
              cy=int(cy/len(blobs))
              #img.draw_cross(cx, cy) # cx, cy
              print(cx,cy)
              return int(cx), int(cy)
          return -1, -1 #表示没有找到
    • while True不是函数,是主循环,不能返回
