  • IDE异常中断是为什么?
    • Edge Impulse - OpenMV Object Detection Example
      import sensor, image, time, os, tf, math, uos, gc
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
      (255, 0, 0),
      ( 0, 255, 0),
      (255, 255, 0),
      ( 0, 0, 255),
      (255, 0, 255),
      ( 0, 255, 255),
      (255, 255, 255),
      # detect() returns all objects found in the image (splitted out per class already)
      # we skip class index 0, as that is the background, and then draw circles of the center
      # of our objects
      for i, detection_list in enumerate(net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)])):
          if (i == 0): continue # background class
          if (len(detection_list) == 0): continue # no detections for this class?
          for d in detection_list:
              [x, y, w, h] = d.rect()
              print('x %d\ty %d' % (center_x, center_y))
              img.draw_circle((center_x, center_y, 12), color=colors[i], thickness=2)
    • IDE interrupt不是错误,是IDE中断了代码。
    • @kidswong999IDE异常中断是为什么? 中说:
      它为啥中断
    • 因为你连接了IDE,所以IDE要中断OpenMV上的代码,然后让你编程。
    • @kidswong999 我要让他继续执行我应该咋办
    • @weun 点击三角号,从头运行代码。
