  • 为什么出现ValueError: invalid syntax for integer with base 10 错误
    • ## Hello World Example‘
      # Welcome to the OpenMV IDE! Click on the green run arrow button below to run the script!
      sensor.set_pixformat(sensor.GRAYSCALE) # Set pi    1xel format to RGB565 (or GRAYSCALE)
      sensor.skip_frames(10)     # Wait for settings take effect.
      uart = UART(3, 9600)
      #sensor.set_auto_exposure()
      string = "hello string!"
      rect_tuple = (140, 100, 40, 40)
      ROI = (140, 100, 40, 40)
      threshold = (112, 0)
      t = 0
          clock.tick()                    # Update the FPS clock.
          image = sensor.snapshot()         # Take a picture and return the image.
          image.binary([threshold], invert = 1)
          statistics=image.get_statistics(roi=ROI)
          avg = json.dumps(statistics.mean())
          image.draw_circle(160,120,50)
          image.draw_cross(160, 120, size=5, color = (255, 0, 0))
          image.draw_rectangle(rect_tuple) #在图像中画一个矩形框
          #print(clock.fps())              # Note: OpenMV Cam runs about half as fast when connected
                                         # to the IDE. The FPS should increase once disconnected.
          if uart.any():
              t = int(uart.read())
          if t == 1:
               uart.write(avg + '\n')
               print('you send:',avg)
    • 因为你串口收到的数据不是数字的字符串。
