  • 如何解决NameError: local variable referenced before assignment
    • import sensor, image, time,math,pyb
      from pyb import UART,LED
      import ustruct
      red_threshold_01=(10, 100, 127, 32, -43, 67)
      uart = UART(3,115200)   #定义串口3变量
      uart.init(115200, bits=8, parity=None, stop=1) # init with given parameters
      def find_max(blobs):    #定义寻找色块面积最大的函数
              if blob.pixels() > max_size:
                  max_size = blob.pixels()
      def sending_data(cx,cy,cw,ch):
          global uart;
          #frame=[0x2C,18,cx%0xff,int(cx/0xff),cy%0xff,int(cy/0xff),0x5B];
          #data = bytearray(frame)
          data = ustruct.pack("<bbhhhhb",      #格式为俩个字符俩个短整型(2字节)
                         0x2C,                      #帧头1
                         0x12,                      #帧头2
                         int(cx), # up sample by 4   #数据1
                         int(cy), # up sample by 4    #数据2
                         int(cw), # up sample by 4    #数据1
                         int(ch), # up sample by 4    #数据2
                         0x5B)
          uart.write(data);   #必须要传入一个字节数组
          blobs = img.find_blobs([red_threshold_01])
          max_b = find_max(blobs)
          cx=0;cy=0;
                  #如果找到了目标颜色
                  cx=max_b[5]
                  cy=max_b[6]
                  cw=max_b[2]
                  ch=max_b[3]
                  img.draw_rectangle(max_b[0:4]) # rect
                  img.draw_cross(max_b[5], max_b[6]) # cx, cy
                  FH = bytearray([0x2C,0x12,cx,cy,cw,ch,0x5B])
                  #sending_data(cx,cy,cw,ch)
                  uart.write(FH)
                  print(cx,cy,cw,ch)
    • 改为
          max_blob=None
