为什么我识别橙红色的时候,把白色也识别出来了?看图中颜色区域为橙红色,而串行终端输出了白色和橙红色,求解答谢谢
import sensor, image, time , math , pyb from pyb import UART sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) sensor.set_auto_whitebal(False) clock = time.clock() a1=0 uart = UART(3, 115200) uart.init(115200, bits=8, parity=None, stop=1) def find_max(blobs): max_size=0 for blob in blobs: if blob[2]*blob[3] > max_size: max_blob = blob max_size = blob[2]*blob[3] return max_blob red_threshold_01 = ((82, 36, 63, 23, 63, 28)); white_threshold_01 = ((75, 100, -18, 2, -4, 23)); pink_threshold_01 = ((48, 100, 5, 127, -25, 12)); while(True): clock.tick() img = sensor.snapshot().lens_corr(1.8) blobs = img.find_blobs([red_threshold_01], pixels_threshold=150, area_threshold=500, merge=True, margin=10); if blobs: #如果找到了目标颜色 print("ored") max_blob_0 = find_max(blobs) for b in blobs: x = b[0] y = b[1] width = b[2] height = b[3] img.draw_rectangle(max_blob_0.rect()) #用矩形标记出目标颜色区域 img.draw_cross(max_blob_0.cx(), max_blob_0.cy()) #在目标颜色区域的中心画十字形标记 print(b[5],b[6],b[7]) X =int(max_blob_0.cx()-img.width()/2) Y =int(max_blob_0.cy()-img.height()/2) blobs = img.find_blobs([white_threshold_01], pixels_threshold=100, area_threshold=200, merge=True, margin=10); if blobs: print("white") max_blob_1 = find_max(blobs) img.draw_rectangle(max_blob_1.rect()) #用矩形标记出目标颜色区域 img.draw_cross(max_blob_1.cx(), max_blob_1.cy()) print("cx: ", max_blob_1.cx()) #打印X的的位置 print("cy: ", max_blob_1.cy()) blobs = img.find_blobs([pink_threshold_01], pixels_threshold=100, area_threshold=100, merge=True, margin=10); if blobs: max_blob_2 = find_max(blobs) img.draw_rectangle(max_blob_2.rect(),color = (255, 0, 0)) #用矩形标记出目标颜色区域 img.draw_cross(max_blob_2.cx(), max_blob_2.cy()) print("pink cx: cy: ", max_blob_2.cx(),max_blob_2.cy()) #打印X的的位置
那说明白色阈值没调好。
