  • 用edgeimpulse训练好的模型,怎么调用openmv实时的识别概率(即使这个值小于最小置信度也需要)
    • # Edge Impulse - OpenMV Object Detection Example
      import sensor, image, time, os, tf, math, uos, gc
      import pyb
      def modified_data(data):
         data = int(data)# 将data转化为整数型变量
         str_data = ''
         if data < 10:                                  # 目标色块的中心点的横坐标、纵坐标或面积的开方<10
             str_data = str_data + '000' + str(data)   # 运用字符串的拼接把色块参数全部转化为长度为四个字符的字符串,如8->“0008”
         elif data >= 10 and data < 100:               # 10<目标色块的中心点的横坐标、纵坐标或面积的开方<100
             str_data = str_data + '00' + str(data)    # 运用字符串的拼接把色块参数全部转化为长度为四个字符的字符串,如88->“0088”
         elif data >=100 and data <1000:               # 100<目标色块的中心点的横坐标、纵坐标或面积的开方<1000
             str_data = str_data + '0' + str(data)     # 运用字符串的拼接把色块参数全部转化为长度为四个字符的字符串,如888->“0888”
         else:                                         # 1000<目标色块的中心点的横坐标、纵坐标或面积的开方
             str_data = str_data + str(data)           # 运用字符串的拼接把色块参数全部转化为长度为四个字符的字符串,如8888->“8888”
         return str_data.encode('utf-8')               # ******将字符串中的每一个字母转化为UTF-8码值(与ASCII码值基本一样)*******
                                                       # ******十进制0对应ASCII码值的48,可进行换算
      net = None
      labels = None
      min_confidence = 0.70
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
          # detect() returns all objects found in the image (splitted out per class already)
          # we skip class index 0, as that is the background, and then draw circles of the center
          # of our objects
          for i, detection_list in enumerate(net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)])):
              if (i == 0): continue # background class
              if (len(detection_list) == 0): continue # no detections for this class?
              for d in detection_list:
                  [x, y, w, h] = d.rect()
                  print('x %d\ty %d' % (center_x, center_y))
                  img.draw_rectangle(d.rect())
                  print(w*h)
                  print(detection_list[0][4])
                  s = detection_list[0][4]
                  print(s)
              if s > 0.75:
                  t = 1
                  x = modified_data(center_x)
                  y = modified_data(center_y)
                  p = modified_data(math.sqrt(w*h))
                  uart.write('st')                                    # 向单片机发送’st’(应该是作为一个发送的起始标志)
                  uart.write(x)                                       # 向单片机发送目标色块的中心点横坐标(经过处理后)
                  uart.write(y)                                       # 向单片机发送目标色块的中心点纵坐标(经过处理后)
                  uart.write(p)
                  time.sleep(0.01)
                  print(t)
              if s < 0.75 and t == 0:
                  uart.write('wz')
                  time.sleep(0.01)
    • 你把最小置信度参数调低,得到的结果就多了。
    • 还有别的方法吗,因为我们要满足识别成熟果子抓取的条件,置信度不能太低
    • 我没看懂你具体要做什么,你不是想得到包括低置信度的结果吗?传入低置信度参数,哪里不满足你的需求?
    • 就是模型里和最小置信度比较的那个值存在那个变量里?
