语法是正确,但这个错误是什么意思,不可迭代
import sensor, image, time from pyb import UART from pyb import LED from image import SEARCH_EX,SEARCH_DS #pink_threshold = (65, 21, 7, 67, 55, -2) #pink_threshold =(42, 62, 67, 14, -16, 65) pink_threshold = (65, 21, 7, 67, 55, -2) pink_color_code = 1 # code = 2^0 = 1 uart = UART(3, 115200) uart.init(115200, bits=8, parity=None, stop=1) #8位数据位,无校验位,1位停止位、 sensor.reset() # 初始化摄像头 sensor.set_contrast(1)#对比度 sensor.set_gainceiling(16)#图像增益上限 sensor.set_pixformat(sensor.RGB565) # 选择像素模式 RGB565. sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed. sensor.skip_frames(time = 2000) # Let new settings take affect. #sensor.set_pixformat(sensor.GRAYSCALE) sensor.set_auto_gain(False) # 颜色跟踪必须关闭自动增益 sensor.set_auto_whitebal(False) #关闭白平衡。白平衡是默认开启的,在颜色识别中,需要关闭白平衡。 templates =["111.pgm","221.pgm","333.pgm","334.pgm","335.pgm","443.pgm","444.pgm.", "555.pgm","556.pgm","557.pgm","666.pgm","667.pgm","777.pgm","778.pgm","888.pgm"] clock = time.clock() # Tracks FPS. shj=0 while(shj == 0): clock.tick() img = sensor.snapshot() img = img.to_grayscale() for t in templates: template = image.Image(t) r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) if r: shj=t[0] LED(2).on() time.sleep_ms(3000) LED(2).off() x=[] for i in range(len(templates)): if shj == templates[i][0]: x.append(templates[i]) flag = 1 while(True): clock.tick() img = sensor.snapshot() img = img.to_grayscale() if flag == 1: for t in x: h = image.Image(t) r = img.find_template(h, 0.70, step=4, search=SEARCH_EX) if r: img.draw_rectangle(r,0) if(r[0]+(r[2]/2) > sensor.width() /2): uartData = bytearray([0xa5,0x2b,0x01]) elif(r[0]+(r[2]/2) < sensor.width()/2): uartData = bytearray([0xa5,0x2b,0x02]) flag = 0 LED(1).on() uart.write(uartData) clock.tick() img = sensor.snapshot() blobs = img.find_blobs([pink_threshold], area_threshold=100) if blobs: ##如果找到了目标颜色 for blob in blobs: ##迭代找到的目标颜色区域 x = blob[0] y = blob[1] # width = blob[2] # 色块矩形的宽度 height = blob[3] # 色块矩形的高度 center_x = blob[5] # 色块中心点x值 center_y = blob[6] # 色块中心点y值 color_code = blob[8] # 颜色代码 ## 添加颜色说明 if color_code == pink_color_code: img.draw_string(x, y - 10, "red", color = (0xFF, 0x00, 0x00)) ##用矩形标记出目标颜色区域 img.draw_rectangle([x, y, width, height]) ##在目标颜色区域的中心画十字形标记 img.draw_cross(center_x, center_y)
这个代码我测试不出来, 因为复现条件很复杂,一直27行的死循环出不来。
建议精简出只出错的部分,可以运行的,一运行就可以复现问题的代码。
@kidswong999 已经解决了,谢谢
