  • 舵机初学者,下载main.py文件,一应用就报错 麻烦了
    • import sensor, image, time
      from pyb import Servo
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      pan_servo.calibration(500,2500,500)
      tilt_servo.calibration(500,2500,500)
      red_threshold = (13, 49, 18, 61, 6, 47)
          max_blob = find_max(blobs)
      IndentationError:unexpected indent
      报错为:
    • 提示的很明显,缩进问题。
    • @kidswong999 气愤,我改
