  • 怎样提高拍照的清晰度
    • 如题,选择用模型匹配进行物体识别,发现分辨率不高,拍照模糊,怎样能提高呢0_1525399960399_阿里旺旺图片20180504101010.jpg
    • @laoguren1122 程序如图
      import time, sensor, image, math
      Reset sensor
      Set sensor settings
      Max resolution for template matching with SEARCH_EX is QQVGA
      You can set windowing to reduce the search image.
      Load template.
      Template should be a small (eg. 32x32 pixels) grayscale image.
      template = image.Image("/ball3.pgm")
      low_threshold = (0, 50)
      high_threshold = (195, 255)
      Run template matching
      for x in range(4):
      r = img.find_template(template, 0.70)
      if r:
          img.draw_rectangle(r,color=0)
      img.find_edges(image.EDGE_CANNY, threshold=(50, 80))
      for c in img.find_circles(threshold = 2500, x_margin = 20, y_margin = 20, r_margin = 20):
      img.draw_circle(c.x(), c.y(), c.r(), color = (0, 0, 0))
      print(c)
    • 来自星瞳实验室APP: [常见问题]Memory Error: FB Alloc collision!内存不够 https://forum.singtown.com/topic/558
