小车巡线的例程运行后看不到中心的绿线,但是调成灰度图却可以看到解析出来的线,是为什么?
例程原代码
THRESHOLD = (0, 61, 19, 127, -128, 127) # Grayscale threshold for dark things... import sensor, image, time from pyb import LED import car from pid import PID rho_pid = PID(p=0.4, i=0) theta_pid = PID(p=0.001, i=0) LED(1).on() LED(2).on() LED(3).on() sensor.reset() sensor.set_vflip(True) sensor.set_hmirror(True) sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQQVGA) # 80x60 (4,800 pixels) - O(N^2) max = 2,3040,000. #sensor.set_windowing([0,20,80,40]) sensor.skip_frames(time = 2000) # WARNING: If you use QQVGA it may take seconds clock = time.clock() # to process a frame sometimes. while(True): clock.tick() img = sensor.snapshot().binary([THRESHOLD]) line = img.get_regression([(100,100,0,0,0,0)], robust = True) if (line): rho_err = abs(line.rho())-img.width()/2 if line.theta()>90: theta_err = line.theta()-180 else: theta_err = line.theta() img.draw_line(line.line(), color = 127) print(rho_err,line.magnitude(),rho_err) if line.magnitude()>8: #if -40<b_err<40 and -30<t_err<30: rho_output = rho_pid.get_pid(rho_err,1) theta_output = theta_pid.get_pid(theta_err,1) output = rho_output+theta_output car.run(50+output, 50-output) else: car.run(0,0) else: car.run(50,-50) pass
灰度图代码
THRESHOLD = (0, 100) # Grayscale threshold for dark things... import sensor, image, time from pyb import LED import car from pid import PID rho_pid = PID(p=0.4, i=0) theta_pid = PID(p=0.001, i=0) LED(1).on() LED(2).on() LED(3).on() sensor.reset() sensor.set_vflip(True) sensor.set_hmirror(True) sensor.set_pixformat(sensor.GRAYSCALE) sensor.set_framesize(sensor.QQQVGA) # 80x60 (4,800 pixels) - O(N^2) max = 2,3040,000. #sensor.set_windowing([0,20,80,40]) sensor.skip_frames(time = 2000) # WARNING: If you use QQVGA it may take seconds clock = time.clock() # to process a frame sometimes. while(True): clock.tick() img = sensor.snapshot().binary([THRESHOLD]) line = img.get_regression([(255,255)], robust = True) if (line): rho_err = abs(line.rho())-img.width()/2 if line.theta()>90: theta_err = line.theta()-180 else: theta_err = line.theta() img.draw_line(line.line(), color = 127) print(rho_err,line.magnitude(),rho_err) if line.magnitude()>8: #if -40<b_err<40 and -30<t_err<30: rho_output = rho_pid.get_pid(rho_err,1) theta_output = theta_pid.get_pid(theta_err,1) output = rho_output+theta_output car.run(50+output, 50-output) else: car.run(0,0) else: car.run(50,-50) pass
第一个代码里面,img.get_regression是在binary下面的,所以img已经是二值化的图。
get_regression的参数也应该是(255,255)。
@kidswong999 将img.get_regression的参数改成(255,255)后还是没有效果
不好意思弄错了,应该是100,100,因为图像还是彩色格式的。
THRESHOLD = (0, 61, 19, 127, -128, 127) # Grayscale threshold for dark things... import sensor, image, time from pyb import LED LED(1).on() LED(2).on() LED(3).on() sensor.reset() sensor.set_vflip(True) sensor.set_hmirror(True) sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQQVGA) # 80x60 (4,800 pixels) - O(N^2) max = 2,3040,000. #sensor.set_windowing([0,20,80,40]) sensor.skip_frames(time = 2000) # WARNING: If you use QQVGA it may take seconds clock = time.clock() # to process a frame sometimes. while(True): img = sensor.snapshot().binary([THRESHOLD]) line = img.get_regression([(100,100)], robust = True) if (line): img.draw_line(line.line(), color = 127)
@kidswong999 在 小车巡线的例程运行后看不到中心的绿线,但是调成灰度图却可以看到解析出来的线,是为什么? 中说:
255,255
感谢!问题解决了
