  • 出现 OSError: Reset Failed ,这是什么原因造成的?
      # Untitled - By: DianlongYang - 周二 9月 8 2020
      sensor.set_pixformat(sensor.RGB565) # grayscale is faster (160x120 max on OpenMV-M7)
      sensor.set_framesize(sensor.QQVGA) # 320 * 240
      sensor.set_auto_gain(False,gain_db=20) #设置增益值(自动增益模式下的典型值为9)
      sensor.set_auto_whitebal(False) #如果开启自动白平衡,设备会自动调整(不同颜色通道的)增益
      sensor.set_auto_exposure(False, exposure_us=37966) #设置曝光时长(自动模式下的典型值是5845us)
      ROI_X = 87  #56  59
      ROI_Y= 25  #2   10
      ROI_W = 38  #40  38
      ROI_H= 70 #75  70
      ROI = (ROI_X,ROI_Y,ROI_W ,ROI_H)
          init12 = time.ticks()
          img.draw_rectangle(ROI,color = (0, 0, 0), thickness = 1, fill = False)
          # 5分条
          img.draw_line((ROI_X+9, 82, ROI_X+9 + 20, 82), color = (255, 0, 0),thickness=1)
          img.draw_line((ROI_X+9, 50, ROI_X+9 + 20, 50), color = (255, 0, 0),thickness=1)
          init32 = time.ticks()
          print(init32 - init12)
    • 估计是硬件坏了,联系卖家维修。
