  • 寻线小车,我把蓝色的线换成黑色的的了阈值改过了以后,小车原地转找不到线,求助
    • 请在这里粘贴代码
      THRESHOLD = (5, 70, -23, 15, -57, 0) # Grayscale threshold for dark things...
      from pyb import LED
      import car
      rho_pid = PID(p=0.4, i=0)
      theta_pid = PID(p=0.001, i=0)
      LED(1).on()
      LED(2).on()
      LED(3).on()
      sensor.set_vflip(True)
      sensor.set_hmirror(True)
      sensor.skip_frames(time = 2000) # WARNING: If you use QQVGA it may take seconds
      clock = time.clock() # to process a frame sometimes.
      if (line):
      if line.theta()>90:
      theta_err = line.theta()-180
      if line.magnitude()>8:
      car.run(50+output, 50-output)
      car.run(0,0)
      car.run(50,-50)
      pass
    • 颜色的阈值不对啊。
    • 如果我要寻白线,是不是只需要改成黑色的阈值了吗?其它的都不用改吗
