  • 为什么对人脸追踪的程序只是加入了打印人脸坐标,每次循环的结果都是一样的没有变化?
    • # Face Tracking Example
      # This example shows off using the keypoints feature of your OpenMV Cam to track
      # a face after it has been detected by a Haar Cascade. The first part of this
      # script finds a face in the image using the frontalface Haar Cascade.
      # After which the script uses the keypoints feature to automatically learn your
      # face and track it. Keypoints can be used to automatically track anything.
      import sensor, time, image
      # Reset sensor
      sensor.set_contrast(3)
      # Skip a few frames to allow the sensor settle down
      # Load Haar Cascade
      print(face_cascade)
      # First set of keypoints
      kpts1 = None
      # Find a face!
      while (kpts1 == None):
          img.draw_string(0, 0, "Looking for a face...")
          # Find faces
          objects = img.find_features(face_cascade, threshold=0.5, scale=1.25)
          if objects:
              # Expand the ROI by 31 pixels in every direction
              face = (objects[0][0]-31, objects[0][1]-31,objects[0][2]+31*2, objects[0][3]+31*2)
              # Extract keypoints using the detect face size as the ROI
              kpts1 = img.find_keypoints(threshold=10, scale_factor=1.1, max_keypoints=100, roi=face)
              # Draw a rectangle around the first face
              img.draw_rectangle(objects[0])
      # Draw keypoints
      print(kpts1)
      img.draw_keypoints(kpts1, size=24)
      time.sleep(2000)
      # FPS clock
          # Extract keypoints from the whole frame
          kpts2 = img.find_keypoints(threshold=10, scale_factor=1.1, max_keypoints=100, normalized=True)
          if (kpts2):
              # Match the first set of keypoints with the second one
              c=image.match_descriptor(kpts1, kpts2, threshold=85)
              match = c[6] # C[6] contains the number of matches.
              if (match>5):
                  img.draw_rectangle(c[2:6])
                  img.draw_cross(c[0], c[1], size=10)
                  t=img.draw_rectangle(c[2:6])
                  print(kpts2, "matched:%d dt:%d"%(match, c[7]))
                  for face in objects:
                      print(face)
          # Draw FPS
          img.draw_string(0, 0, "FPS:%.2f"%(clock.fps()))
    • 只是加了这一句
      print(face)
    • 串口显示结果
      {"size":54, "threshold":10, "normalized":1} matched:18 dt:0
      (46, 8, 182, 182)
      {"size":50, "threshold":10, "normalized":1} matched:17 dt:0
      (46, 8, 182, 182)
      {"size":53, "threshold":10, "normalized":1} matched:18 dt:0
      (46, 8, 182, 182)
      {"size":52, "threshold":10, "normalized":1} matched:17 dt:0
      (46, 8, 182, 182)
      {"size":56, "threshold":10, "normalized":1} matched:18 dt:0
      (46, 8, 182, 182)
      {"size":62, "threshold":10, "normalized":1} matched:18 dt:0
      (46, 8, 182, 182)
      {"size":55, "threshold":10, "normalized":1} matched:15 dt:0
      (46, 8, 182, 182)
      {"size":70, "threshold":10, "normalized":1} matched:10 dt:0
      (46, 8, 182, 182)
      {"size":85, "threshold":10, "normalized":1} matched:11 dt:0
      (46, 8, 182, 182)
      {"size":61, "threshold":10, "normalized":1} matched:9 dt:0
      (46, 8, 182, 182)
      {"size":58, "threshold":10, "normalized":1} matched:8 dt:0
      (46, 8, 182, 182)
      {"size":49, "threshold":10, "normalized":1} matched:7 dt:0
      (46, 8, 182, 182)
      {"size":51, "threshold":10, "normalized":1} matched:8 dt:0
      (46, 8, 182, 182)
      {"size":30, "threshold":10, "normalized":1} matched:7 dt:0
      (46, 8, 182, 182)
      {"size":44, "threshold":10, "normalized":1} matched:6 dt:0
      (46, 8, 182, 182)
      {"size":45, "threshold":10, "normalized":1} matched:8 dt:0
      (46, 8, 182, 182)
      {"size":45, "threshold":10, "normalized":1} matched:9 dt:0
      (46, 8, 182, 182)
      {"size":37, "threshold":10, "normalized":1} matched:6 dt:15
      (46, 8, 182, 182)
      {"size":41, "threshold":10, "normalized":1} matched:6 dt:15
      (46, 8, 182, 182)
      {"size":45, "threshold":10, "normalized":1} matched:6 dt:270
      (46, 8, 182, 182)
      {"size":38, "threshold":10, "normalized":1} matched:8 dt:15
      (46, 8, 182, 182)
      {"size":46, "threshold":10, "normalized":1} matched:8 dt:15
      (46, 8, 182, 182)
      {"size":43, "threshold":10, "normalized":1} matched:7 dt:0
      (46, 8, 182, 182)
      {"size":40, "threshold":10, "normalized":1} matched:7 dt:15
      (46, 8, 182, 182)
      {"size":49, "threshold":10, "normalized":1} matched:9 dt:30
      (46, 8, 182, 182)
      {"size":38, "threshold":10, "normalized":1} matched:7 dt:0
      (46, 8, 182, 182)
      {"size":63, "threshold":10, "normalized":1} matched:8 dt:0
      (46, 8, 182, 182)
      {"size":53, "threshold":10, "normalized":1} matched:8 dt:0
      (46, 8, 182, 182)
      {"size":49, "threshold":10, "normalized":1} matched:9 dt:0
      (46, 8, 182, 182)
      {"size":43, "threshold":10, "normalized":1} matched:6 dt:0
      (46, 8, 182, 182)
      {"size":47, "threshold":10, "normalized":1} matched:7 dt:0
      (46, 8, 182, 182)
      {"size":42, "threshold":10, "normalized":1} matched:6 dt:0
      (46, 8, 182, 182)
      {"size":41, "threshold":10, "normalized":1} matched:7 dt:0
      (46, 8, 182, 182)
      {"size":34, "threshold":10, "normalized":1} matched:7 dt:0
      (46, 8, 182, 182)
      {"size":21, "threshold":10, "normalized":1} matched:8 dt:0
      (46, 8, 182, 182)
      {"size":29, "threshold":10, "normalized":1} matched:6 dt:0
      (46, 8, 182, 182)
      {"size":24, "threshold":10, "normalized":1} matched:9 dt:0
      (46, 8, 182, 182)
      (46, 8, 182, 182)
      {"size":23, "threshold":10, "normalized":1} matched:7 dt:0
      (46, 8, 182, 182)
      {"size":29, "threshold":10, "normalized":1} matched:8 dt:0
      (46, 8, 182, 182)
      (46, 8, 182, 182)
      Traceback (most recent call last):
        File "<stdin>", line 56, in <module>
      Exception: IDE interrupt
      MicroPython v1.9.4-4553-gb4eccdfe3 on 2019-05-02; OPENMV4 with STM32H743
    • 代码垃圾。逻辑完全不对。
      你的代码有两个while死循环,第二个死循环永远不会运行。
    • 我建议你从头开始看教程,把每一句代码的作用都搞懂。不要单纯的复制粘贴。
    已锁定
