应该怎么用uart.write来发送数据呢?
我的目的是通过颜色识别和返回舵机角度来确定目标位置,现在能通过uart.write函数返回字符串,但是不能返回一个变量所代表的值,请问问题出在哪里了呢?
import sensor, image, time,pyb from pid import PID from pyb import Servo from pyb import UART pan_servo=Servo(1) red_threshold = (13, 49, 18, 61, 6, 47) pan_pid = PID(p=0.07, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID uart = pyb.UART(3, 115200, timeout_char = 1000) #pan_pid = PID(p=0.1, i=0, imax=90)#在线调试使用这个PID #tilt_pid = PID(p=0.1, i=0, imax=90)#在线调试使用这个PID sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.RGB565) # use RGB565. sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed. sensor.skip_frames(10) # Let new settings take affect. sensor.set_auto_whitebal(False) # turn this off. clock = time.clock() # Tracks FPS. def find_max(blobs): max_size=5 for blob in blobs: if blob[2]*blob[3] > max_size: max_blob=blob max_size = blob[2]*blob[3] return max_blob while(True): clock.tick() # Track elapsed milliseconds between snapshots(). img = sensor.snapshot() # Take a picture and return the image. blobs = img.find_blobs([red_threshold]) if blobs: max_blob = find_max(blobs) pan_error = max_blob.cx()-img.width()/2 print("pan_error: ", pan_error) img.draw_rectangle(max_blob.rect()) # rect img.draw_cross(max_blob.cx(), max_blob.cy()) # cx, cy pan_output=pan_pid.get_pid(pan_error,1)/2 print("pan_output",pan_output) pan_servo.angle(pan_servo.angle()+pan_output) out_date=pan_servo.angle()+pan_output uart.write(out_date) 请在这里粘贴代码
多谢,已经解决了
请问怎么解决的呢
@uc5f 看视频解决的。
