  • 对上传的图片分别选取了四个ROI识别其中的矩形,但只能识别到左上角的矩形,其他区域识别不到是什么原因?
    • # Find Rects Example
      # (但是,这个代码也会检测小半径的圆)...
          img = sensor.snapshot().lens_corr(strength = 1.8, zoom = 1.0)
          # 下面的`threshold`应设置为足够高的值,以滤除在图像中检测到的具有
          # 低边缘幅度的噪声矩形。最适用与背景形成鲜明对比的矩形。
          for r1 in img.find_rects(roi = (0,0,100,100),threshold = 1000):
              img.draw_rectangle(r1.rect(), color = (255, 0, 0))
              print("1")
              print(r1.rect())
          for r2 in img.find_rects(roi = (400,0,240,200),threshold = 1000):
              img.draw_rectangle(r2.rect(), color = (255, 0, 0))
              print("2")
              print(r2.rect())
          for r3 in img.find_rects(roi = (0,350,100,100),threshold = 1000):
              img.draw_rectangle(r3.rect(), color = (255, 0, 0))
              print("3")
              print(r3.rect())
          for r4 in img.find_rects(roi = (300,350,340,100),threshold = 1000):
              img.draw_rectangle(r4.rect(), color = (255, 0, 0))
              print("4")
              print(r4.rect())
    • 我感觉是固件有计算错误,已经提交issue
      https://github.com/openmv/openmv/issues/1854
