  • edgeimpluse 训练出来的代码报错 Failed to load "trained.tflite两个文件都在盘里
    • Edge Impulse - OpenMV Image Classification Example
      net = None
      labels = None
      except Exception as e:
      print(e)
      print(clock.fps(), "fps")
      点击运行报这个错误是怎么回事Exception: Failed to load "trained.tflite" , did you copythe .tflite and labels.txt file onto the mass-storagedevice? (Out of fast Frame Buffer Stack Memory! Pleasereduce the resolution of the image you are running thisalgorithm on to bypass this issue!)。我确定我的openmv 在没插入内存卡之前是几百KB的内存大小,插入内存卡之后是29.5G的内存,我也把edge impluse 训练完的三个文件都拖入到了openmv插入电脑后的盘(F盘)里,可还是报这个错。我之前已经做过两次openmv识别的了,都不会这样,是不是这个openmv坏了,还是内存卡坏了
    • 估计你使用的是OpenMV4 H7,而不是OpenMV4 H7 Plus。
      如果是OpenMV4 H7,用星瞳AI云服务训练,可以生成。
      https://docs.singtown.com/ai/zh/latest/toturial/classify.html
