  • 在openmv ide中如何引用numpy库呢 是无法引用吗
    • import numpy as np
      import cv2
      def find_marker(Img):
          kernel_2 = np.ones((2,2),np.uint8)#2x2的卷积核
          kernel_3 = np.ones((3,3),np.uint8)#3x3的卷积核
          kernel_4 = np.ones((4,4),np.uint8)#4x4的卷积核
          if Img is not None:#判断图片是否读入
              HSV = cv2.cvtColor(Img, cv2.COLOR_BGR2HSV)#把BGR图像转换为HSV格式
              HSV模型中颜色的参数分别是:色调(H),饱和度(S),明度(V)
              下面两个值是要识别的颜色范围
              Lower = np.array([0, 128, 46])#要识别红色颜色的下限
              Upper = np.array([5, 255,  255])#要识别红色颜色的上限
              #mask是把HSV图片中在颜色范围内的区域变成白色,其他区域变成黑色
              mask = cv2.inRange(HSV, Lower, Upper)
              #下面四行是用卷积进行滤波
              erosion = cv2.erode(mask,kernel_4,iterations = 1)
              erosion = cv2.erode(erosion,kernel_4,iterations = 1)
              dilation = cv2.dilate(erosion,kernel_4,iterations = 1)
              dilation = cv2.dilate(dilation,kernel_4,iterations = 1)
              #target是把原图中的非目标颜色区域去掉剩下的图像
              target = cv2.bitwise_and(Img, Img, mask=dilation)
              #将滤波后的图像变成二值图像放在binary中
              ret, binary = cv2.threshold(dilation,127,255,cv2.THRESH_BINARY)
              #在binary中发现轮廓,轮廓按照面积从小到大排列
              (_, cnts, _)= cv2.findContours(binary,cv2.RETR_EXTERNAL,cv2.CHAIN_APPROX_SIMPLE)
              if cnts==[]:
                 return 0
          c= max(cnts, key = cv2.contourArea)
          return cv2.minAreaRect(c)
      def distance_to_camera(knownWidth, focalLength, perWidth):
          return (knownWidth * focalLength) / perWidth
      KNOWN_DISTANCE = 102
      KNOWN_WIDTH = 19
      KNOWN_HEIGHT = 8.27
      image = cv2.imread("/home/pi/Pictures/distanceTest.jpeg")
      marker = find_marker(image)
      focalLength = (marker[1][0] * KNOWN_DISTANCE) / KNOWN_WIDTH
      camera = cv2.VideoCapture(0)
      while camera.isOpened():
          (grabbed, frame) = camera.read()
          marker = find_marker(frame)
          if marker == 0:
             cv2.imshow("captureR", frame)
             cv2.destroyWindow("captureR")
             continue
          inches = distance_to_camera(KNOWN_WIDTH, focalLength, marker[1][0])
          box = cv2.boxPoints(marker)
          box = np.int0(box)
          cv2.drawContours(frame, [box], -1, (0, 255, 0), 2)
          cv2.putText(frame, "%.2fcm" % (inches),
                   (frame.shape[1] - 600, frame.shape[0] - 20), cv2.FONT_HERSHEY_SIMPLEX,
               2.0, (0, 255, 0), 3)
          cv2.imshow("capture", frame)
          if cv2.waitKey(1) & 0xFF == ord('q'):
              break
      camera.release()
      cv2.destroyWindow("capture")
    • OpenMV不能使用cv2和numpy.
