  • 请问对一张图片边缘检测完后,如何保存获得的边缘图像?
    • 完整描述:从sd卡中读取某一张图片,然后进行边缘检测,接着保存framebuffer中的边缘图像至sd卡中
      # 仍然需要初始化 sensor
      # 设置 sensor
      # 设置sensor的像素格式
      kernel = [-1, -1, -1,\
                -1, +8, -1,\
                -1, -1, -1]
      thresholds = [(100, 255)] # grayscale thresholds设置阈值
      # 导入 image
      img = image.Image("/example.bmp", copy_to_fb=True)
      img.binary(thresholds)
      img.erode(1, threshold = 2)
      img.save('binary.bmp')
      # Flush FB
      sensor.flush()
      # Add a small delay to allow the IDE to read the flushed image.
      # 添加一个小的延迟,以允许IDE读取刷新后的图像
      time.sleep_ms(100)
      参考代码:
      https://book.openmv.cc/example/03-Drawing/copy2fb.html
      https://book.openmv.cc/example/04-Image-Filters/edge-detection.html
