  • openmvWiFi传输图像为什么在接收端显示错误?
    • 将openmv用作STA接入局域网中,向另一端口传输图片,以下是openmv端的代码:
      import sensor, image, time, socket, network, io
      wlan = network.WLAN(network.STA_IF)     #STA模式
      wlan.active(True)
      if not wlan.isconnected():              #网络连接
          print('connecting to network...')
          wlan.connect('5352123', 'fasdfagdad')
          while not wlan.isconnected():
              pass
      print('网络配置:', wlan.ifconfig())
      sensor.reset()                          #设定摄像头参数
      sensor.set_pixformat(sensor.JPEG)
      sensor.set_vflip(True)                  #垂直翻转
      sensor.set_framesize(sensor.HVGA)
      s = socket.socket(socket.AF_INET,socket.SOCK_DGRAM,0)   #UDP传输
          img = sensor.snapshot()                 #拍摄图片
          #img = img.compressed(quality=35)
          s.sendto(img,("192.168.1.112",5454))    #接收端地址
          #print(img)
      用python在目标地址电脑上产生一个接收端程序,代码如下:
      import socket
      import cv2
      import io
      import numpy as np
      from PIL import Image
      from PIL import ImageFile
      ImageFile.LOAD_TRUNCATED_IMAGES = True
      s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM, 0)     #UDP传输
      s.bind(("0.0.0.0", 5454))                                   #端口号
          data, IP = s.recvfrom(100000)       #接收数据
          bytes_stream = io.BytesIO(data)     #转化为二进制流
          image = Image.open(bytes_stream)    #打开图片
          img = np.asarray(image)
          img = cv2.cvtColor(img, cv2.COLOR_RGB2BGR)  # 传输的是RGB格式,要转换为BGR(opencv的格式)
          cv2.imshow("ESP32 Capture Image", img)
          if cv2.waitKey(1) == ord("q"):      #退出条件
              break
      在运行后显示如下错误:
      File "D:\python\wifi\main.py", line 15, in
      File "D:\Anaconda3\envs\gjp\lib\site-packages\PIL\Image.py", line 3298, in open
      raise UnidentifiedImageError(msg)
      PIL.UnidentifiedImageError: cannot identify image file <_io.BytesIO object at 0x00000206C87E03B0>
      提示不能识别文件,这是什么原因导致的?
    • 你用的是官方的OpenMV和WiFi扩展板?
    • 是的,用的官方的
      1. 用tcp,而不是udp. udp不能保证收到的格式是对的.
      2. OpenMV端发送jpeg格式的代码.接收端先保存成jpeg来查看对不对.
