  • openmv读取引脚状态来进行接下来的if判断等,但是外部电平发生改变时,openmv没有反应?
      import car
      sensor.skip_frames(10)
      green_threshold   = (76, 96, -110, -30, 8, 66)
      #size_threshold = 2000
      x_pid = PID(p=0.25, i=1, imax=10)
      #h_pid = PID(p=0.05, i=0.1, imax=50)
      pwmm1=0
      pwmm2=0
          p_in = Pin('P0', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻
          value0 = p_in.value() # get value, 0 or 1#读入p_in引脚的值  stoPf  p60
          p_in = Pin('P1', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻
          value1 = p_in.value() # get value, 0 or 1#读入p_in引脚的值 unstop  p61
          p_in = Pin('P2', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻
          value2 = p_in.value() # get value, 0 or 1#读入p_in引脚的值  hand   p62
          p_in = Pin('P3', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻
          value3 = p_in.value() # get value, 0 or 1#读入p_in引脚的值  zidong p63
          p_in = Pin('P4', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻
          value4 = p_in.value() # get value, 0 or 1#读入p_in引脚的值  front  p66
          p_in = Pin('P5', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻
          value5 = p_in.value() # get value, 0 or 1#读入p_in引脚的值  left   p67
          p_in = Pin('P6', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻
          value6 = p_in.value() # get value, 0 or 1#读入p_in引脚的值  turn   p65
          if value1==1#不停止标志位
              if value3==1#自动标志位
                      print("x error: ", x_error)
                      for b in blobs:
                      #print("h_output",h_output)
                      pwmm1=11-x_output
                      pwmm2=11+x_output
                      if (pwmm1)<8:
                          pwmm1=8
                      elif (pwmm1)>11:
                          pwmm1=11
                          pwmm1=pwmm1
                      if pwmm2<8:
                          pwmm2=8
                      elif pwmm2>11:
                          pwmm2=11
                          pwmm2=pwmm2
                      else
      		    car.run(pwmm1,pwmm2)
              if value2==1#手动标志位
                  if value4==1:#前进标志位
                      car.run(8,8)
                  if value5==1: #左转标志位
                      car.run(8,0)
                  if value6==1:#右转标志位
                      car.run(0,8)
          if value0==1#停止标志位
              car.run(0,0)
    • 运行这个代码进行测试,注意代码开启了内部上拉电阻,所以一直是1,把引脚连到GND会是0.
      from pyb import Pin
      p0 = Pin('P0', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻
      p1 = Pin('P1', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻
      p2 = Pin('P2', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻
      p3 = Pin('P3', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻
      p4 = Pin('P4', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻
      p5 = Pin('P5', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻
      p6 = Pin('P6', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻
          print(p0.value(), p1.value(), p2.value(), p3.value(), p4.value(), p5.value(), p6.value())
          time.sleep_ms(100)
