  • openmv识别到一个目标后怎么让openmv后面只识别这一个目标?
      import sensor, image, time, os, tf, math, uos, gc,ustruct
      uart = UART(3, 19200)
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
          # of our objects
          R = net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)])
          for i, detection_list in enumerate(R):
              for d in detection_list:
                  [x, y, w, h] = d.rect()
                  if (center_x < 160 ):
                      Lor=1
                      Lor=2
                  print(Lor)
                  output_L = json.dumps(Lor)
                  img.draw_circle((center_x, center_y, 33), color=colors[i], thickness=2)
                  sj=bytearray([i,center_x])
                  # uart.write(sj)
                  uart.write(labels[i] +  ' ' + output_L +'\r\n')
    • 没有跟踪的算法,你可以根据上次的坐标,找到这次的离得最近的那个。
