  • 运行代码后一直闪白灯,屏幕卡死,然后就识别不了openmv了
    • # This code run in OpenMV4 H7 or OpenMV4 H7 Plus
      sensor.set_pixformat(sensor.GRAYSCALE)    # Set pixel format to RGB565 (or GRAYSCALE)
          img = sensor.snapshot().binary([(0,64)])
          for obj in tf.classify("trained.tflite", img, min_scale=1.0, scale_mul=0.5, x_overlap=0.0, y_overlap=0.0):
              output = obj.output()
              number = output.index(max(output))
              print(number)
          print(clock.fps(), "fps")
    • https://singtown.com/learn/50661/
      重新烧录固件应该可以解决。
      运行代码闪白灯,估计是固件没有更新到最新版。
      如果无法烧录固件,可以寄回维修。
