  • 求救!!! 無法使用OpenMV的upip套件
      主程式
      import upip
      import network
      ssid = "Zouyk"
      password = "zouyk0219"
      # 連接 WiFi
      wlan = network.WLAN(network.STA_IF)
      wlan.active(True)
      wlan.connect(ssid, password)
      # 等待 WiFi 連線成功
      while not wlan.isconnected():
          time.sleep(1)
      # 印出 IP 位置
      print(wlan.ifconfig()[0])
      upip.install('micropython-ujson')
      upip套件
      # upip - Package manager for MicroPython
      # Copyright (c) 2015-2018 Paul Sokolovsky
      # Licensed under the MIT license.
      import sys
      import gc
      import uos as os
      import uerrno as errno
      import ujson as json
      import uzlib
      import upip_utarfile as tarfile
      debug = False
      install_path = None
      cleanup_files = []
      gzdict_sz = 16 + 15
      file_buf = bytearray(512)
      class NotFoundError(Exception):
          pass
      def op_split(path):
          if path == "":
              return ("", "")
          r = path.rsplit("/", 1)
          if len(r) == 1:
              return ("", path)
          head = r[0]
          if not head:
              head = "/"
          return (head, r[1])
      def op_basename(path):
          return op_split(path)[1]
      # Expects *file* name
      def _makedirs(name, mode=0o777):
          ret = False
          s = ""
          comps = name.rstrip("/").split("/")[:-1]
          if comps[0] == "":
              s = "/"
          for c in comps:
              if s and s[-1] != "/":
                  s += "/"
              s += c
                  os.mkdir(s)
                  ret = True
              except OSError as e:
                  if e.args[0] != errno.EEXIST and e.args[0] != errno.EISDIR:
                      raise
                  ret = False
          return ret
      def save_file(fname, subf):
          global file_buf
          with open(fname, "wb") as outf:
                  sz = subf.readinto(file_buf)
                  if not sz:
                      break
                  outf.write(file_buf, sz)
      def install_tar(f, prefix):
          meta = {}
          for info in f:
              #print(info)
              fname = info.name
                  fname = fname[fname.index("/") + 1:]
              except ValueError:
                  fname = ""
              save = True
              for p in ("setup.", "PKG-INFO", "README"):
                      #print(fname, p)
                      if fname.startswith(p) or ".egg-info" in fname:
                          if fname.endswith("/requires.txt"):
                              meta["deps"] = f.extractfile(info).read()
                          save = False
                          if debug:
                              print("Skipping", fname)
                          break
              if save:
                  outfname = prefix + fname
                  if info.type != tarfile.DIRTYPE:
                      if debug:
                          print("Extracting " + outfname)
                      _makedirs(outfname)
                      subf = f.extractfile(info)
                      save_file(outfname, subf)
          return meta
      def expandhome(s):
          if "~/" in s:
              h = os.getenv("HOME")
              s = s.replace("~/", h + "/")
          return s
      import ussl
      import usocket
      warn_ussl = True
      def url_open(url):
          global warn_ussl
          if debug:
              print(url)
          proto, _, host, urlpath = url.split('/', 3)
              ai = usocket.getaddrinfo(host, 443, 0, usocket.SOCK_STREAM)
              fatal("Unable to resolve %s (no Internet?)" % host, e)
          #print("Address infos:", ai)
          ai = ai[0]
          s = usocket.socket(ai[0], ai[1], ai[2])
              #print("Connect address:", addr)
              s.connect(ai[-1])
              if proto == "https:":
                  s = ussl.wrap_socket(s, server_hostname=host)
                  if warn_ussl:
                      print("Warning: %s SSL certificate is not validated" % host)
                      warn_ussl = False
              # MicroPython rawsocket module supports file interface directly
              s.write("GET /%s HTTP/1.0\r\nHost: %s\r\n\r\n" % (urlpath, host))
              l = s.readline()
              protover, status, msg = l.split(None, 2)
              if status != b"200":
                  if status == b"404" or status == b"301":
                      raise NotFoundError("Package not found")
                  raise ValueError(status)
              while 1:
                  l = s.readline()
                  if not l:
                      raise ValueError("Unexpected EOF in HTTP headers")
                  if l == b'\r\n':
                      break
          except Exception as e:
              s.close()
              raise e
          return s
      def get_pkg_metadata(name):
          f = url_open("https://pypi.org/pypi/%s/json" % name)
              return json.load(f)
          finally:
              f.close()
      def fatal(msg, exc=None):
          print("Error:", msg)
          if exc and debug:
              raise exc
          sys.exit(1)
      def install_pkg(pkg_spec, install_path):
          data = get_pkg_metadata(pkg_spec)
          latest_ver = data["info"]["version"]
          packages = data["releases"][latest_ver]
          del data
          gc.collect()
          assert len(packages) == 1
          package_url = packages[0]["url"]
          print("Installing %s %s from %s" % (pkg_spec, latest_ver, package_url))
          package_fname = op_basename(package_url)
          f1 = url_open(package_url)
              f2 = uzlib.DecompIO(f1, gzdict_sz)
              f3 = tarfile.TarFile(fileobj=f2)
              meta = install_tar(f3, install_path)
          finally:
              f1.close()
          del f3
          del f2
          gc.collect()
          return meta
      def install(to_install, install_path=None):
          gc.collect()
          # Calculate gzip dictionary size to use
          global gzdict_sz
          sz = gc.mem_free() + gc.mem_alloc()
          if sz <= 65536:
              gzdict_sz = 16 + 12
          if install_path is None:
              install_path = get_install_path()
          if install_path[-1] != "/":
              install_path += "/"
          if not isinstance(to_install, list):
              to_install = [to_install]
          print("Installing to: " + install_path)
          # sets would be perfect here, but don't depend on them
          installed = []
              while to_install:
                  if debug:
                      print("Queue:", to_install)
                  pkg_spec = to_install.pop(0)
                  if pkg_spec in installed:
                      continue
                  meta = install_pkg(pkg_spec, install_path)
                  installed.append(pkg_spec)
                  if debug:
                      print(meta)
                  deps = meta.get("deps", "").rstrip()
                  if deps:
                      deps = deps.decode("utf-8").split("\n")
                      to_install.extend(deps)
              print("Error installing '{}': {}, packages may be partially installed".format(
                      pkg_spec, e),
                  file=sys.stderr)
          gc.collect()
      def get_install_path():
          global install_path
              # sys.path[0] is current module's path
              install_path = sys.path[1]
          install_path = expandhome(install_path)
          return install_path
      def cleanup():
          for fname in cleanup_files:
                  os.unlink(fname)
              except OSError:
                  print("Warning: Cannot delete " + fname)
      def help():
          print("""\
      upip - Simple PyPI package manager for MicroPython
      Usage: micropython -m upip install [-p <path>] <package>... | -r <requirements.txt>
      import upip; upip.install(package_or_list, [<path>])
      If <path> is not given, packages will be installed into sys.path[1]
      (can be set from MICROPYPATH environment variable, if current system
      supports that).""")
          print("Current value of sys.path[1]:", sys.path[1])
          print("""\
      Note: only MicroPython packages (usually, named micropython-*) are supported
      for installation, upip does not support arbitrary code in setup.py.
      def main():
          global debug
          global install_path
          install_path = None
          if len(sys.argv) < 2 or sys.argv[1] == "-h" or sys.argv[1] == "--help":
              help()
              return
          if sys.argv[1] != "install":
              fatal("Only 'install' command supported")
          to_install = []
          i = 2
          while i < len(sys.argv) and sys.argv[i][0] == "-":
              opt = sys.argv[i]
              i += 1
              if opt == "-h" or opt == "--help":
                  help()
                  return
              elif opt == "-p":
                  install_path = sys.argv[i]
                  i += 1
              elif opt == "-r":
                  list_file = sys.argv[i]
                  i += 1
                  with open(list_file) as f:
                          l = f.readline()
                          if not l:
                              break
                          if l[0] == "#":
                              continue
                          to_install.append(l.rstrip())
              elif opt == "--debug":
                  debug = True
                  fatal("Unknown/unsupported option: " + opt)
          to_install.extend(sys.argv[i:])
          if not to_install:
              help()
              return
          install(to_install)
          if not debug:
              cleanup()
      if __name__ == "__main__":
          main()
    • 你需要什么库,就直接下载复制到OpenMV就完事了。另外json是直接内置在OpenMV里面的,不需要额外下载。
