沒辦引用urequests.py 請問有什麼問題?
這邊報錯
import usocket class Response: def __init__(self, f): self.raw = f self.encoding = "utf-8" self._cached = None def close(self): if self.raw: self.raw.close() self.raw = None self._cached = None @property def content(self): if self._cached is None: try: self._cached = self.raw.read() finally: self.raw.close() self.raw = None return self._cached @property def text(self): return str(self.content, self.encoding) def json(self): import ujson return ujson.loads(self.content) def request(method, url, data=None, json=None, headers={}, stream=None, parse_headers=True): redir_cnt = 1 while True: try: proto, dummy, host, path = url.split("/", 3) except ValueError: proto, dummy, host = url.split("/", 2) path = "" if proto == "http:": port = 80 elif proto == "https:": import ussl port = 443 else: raise ValueError("Unsupported protocol: " + proto) if ":" in host: host, port = host.split(":", 1) port = int(port) ai = usocket.getaddrinfo(host, port, 0, usocket.SOCK_STREAM) ai = ai[0] resp_d = None if parse_headers is not False: resp_d = {} s = usocket.socket(ai[0], ai[1], ai[2]) try: s.connect(ai[-1]) if proto == "https:": s = ussl.wrap_socket(s, server_hostname=host) s.write(b"%s /%s HTTP/1.0\r\n" % (method, path)) if not "Host" in headers: s.write(b"Host: %s\r\n" % host) # Iterate over keys to avoid tuple alloc for k in headers: s.write(k) s.write(b": ") s.write(headers[k]) s.write(b"\r\n") if json is not None: assert data is None import ujson data = ujson.dumps(json) s.write(b"Content-Type: application/json\r\n") if data: s.write(b"Content-Length: %d\r\n" % len(data)) s.write(b"Connection: close\r\n\r\n") if data: s.write(data) l = s.readline() #print(l) l = l.split(None, 2) status = int(l[1]) reason = "" if len(l) > 2: reason = l[2].rstrip() while True: l = s.readline() if not l or l == b"\r\n": break #print(l) if l.startswith(b"Transfer-Encoding:"): if b"chunked" in l: raise ValueError("Unsupported " + l) elif l.startswith(b"Location:") and 300 <= status <= 399: if not redir_cnt: raise ValueError("Too many redirects") redir_cnt -= 1 url = l[9:].decode().strip() #print("redir to:", url) status = 300 break if parse_headers is False: pass elif parse_headers is True: l = l.decode() k, v = l.split(":", 1) resp_d[k] = v.strip() else: parse_headers(l, resp_d) except OSError: s.close() raise if status != 300: break resp = Response(s) resp.status_code = status resp.reason = reason if resp_d is not None: resp.headers = resp_d return resp def head(url, **kw): return request("HEAD", url, **kw) def get(url, **kw): return request("GET", url, **kw) def post(url, **kw): return request("POST", url, **kw) def put(url, **kw): return request("PUT", url, **kw) def patch(url, **kw): return request("PATCH", url, **kw) def delete(url, **kw): return request("DELETE", url, **kw) ```在這邊報錯
主文件代码呢?
主程式
import network import json import time import ujson import ssl import os import gc import urequests #import firebase_admin #from firebase_admin.firebase_admin import credentials # WiFi 網路設定 #ssid = "Zouyk" #password = "zouyk0219" # Firebase 儲存庫的網址 FIREBASE_URL = ************************** ssid = "Zouyk" password = "zouyk0219" # 連接 WiFi wlan = network.WLAN(network.STA_IF) wlan.active(True) wlan.connect(ssid, password) # 等待 WiFi 連線成功 while not wlan.isconnected(): time.sleep(1) # 印出 IP 位置 print(wlan.ifconfig()[0]) 設置 Firebase 認證信息 cred = credentials.Certificate("openmv-test-45904-firebase-adminsdk-lupkk-6d46339002.json") firebase_admin.initialize_app(cred, { 'databaseURL': 'https://openmv-test-45904-default-rtdb.firebaseio.com/' }) 儲存一個字串到 Firebase my_string = 'Hello, Firebase!' ref = db.reference('messages') ref.set({'message': my_string}) # 定義一個函式,用來上傳資料到 Firebase try: def save_data_to_firebase(data): headers = {'Content-type': 'application/json'} response = urequests.put(FIREBASE_URL, data=ujson.dumps(data), headers=headers) print('Firebase 回應:', response.content) except Exception as e: print('發生錯誤:', e) # 儲存一個字串到 Firebase my_string = 'Hello, Firebase!' data = {'message': my_string} save_data_to_firebase(data)
