WiFi模块发布图象网页,可以用非阻塞链接吗?
买了WiFi模块,用IDE自带例程没问题,根据文档可以用非阻塞链接,并推荐用select的Poll类,我的代码:
# MJPEG Streaming # # This example shows off how to do MJPEG streaming to a FIREFOX webrowser # Chrome, Firefox and MJpegViewer App on Android have been tested. # Connect to the IP address/port printed out from ifconfig to view the stream. import sensor, image, time, network, usocket, sys import select SSID ='ZhaoBao' # Network SSID KEY ='19431121' # Network key HOST ='192.168.1.30' # Use first available interface PORT = 8080 # Arbitrary non-privileged port # Reset sensor sensor.reset() sensor.set_framesize(sensor.QQVGA) sensor.set_pixformat(sensor.RGB565) gs = [] # Init wlan module and connect to network print("Trying to connect... (may take a while)...") wlan = network.WINC() wlan.ifconfig(('192.168.1.30', '255.255.255.0', '192.168.1.1', '192.168.1.1')) wlan.connect(SSID, key=KEY, security=wlan.WPA_PSK) # We should have a valid IP now via DHCP print(wlan.ifconfig()) # Create server socket s = usocket.socket(usocket.AF_INET, usocket.SOCK_STREAM) # Bind and listen s.bind([HOST, PORT]) gs.append(s) s.listen(5) # Set server socket to blocking s.setblocking(False) p = select.poll() p.register(s) while (True): try: events = p.poll(900) if (len(events) > 0): print(events) for fd,event in events: if fd in gs: c,addr = s.accept() print('got connection from',addr) p.register(c,select.POLLIN) gs[0] = c elif event & select.POLLIN: data = c.recv[1024] if not data: print(c.getpeername,'disconnected') p.unregister(c) del gs[0] else: print (data) except OSError as e: print("poll error:",e) continue
但是执行到”events = p.poll(900)“都出错[Error 5] EIO,是不是系统不支持呀?
请教哪位老师帮助检查一下问题出错在哪里呢?谢谢了!
不能用poll。非阻塞,就是如果没有连接就返回错误或者空,需要自己轮询。
