  • 巡线问题为什么会出现下面的问题?
    • 为什么摄像头对这黑线后卡住一会才出来线性回归线而且不是实时的
      BLACK_THRESHOLD = (34, 100, -61, 77, -76, 116)#(100, 55, -35, 22, 22, 82)#(3, 41, -3, 77, 12, 70)#(0, 95, 1, 34, 36, 80) #(5, 89, 35, 75, -8, 50)# Grayscale threshold for dark things...
      import sensor, image, time , math ,struct
      from struct import pack, unpack
      #sensor.set_vflip(True)
      #sensor.set_hmirror(True)
      sensor.set_framesize(sensor.QVGA) # 80x60 (4,800 pixels) - O(N^2) max = 2,3040,000.
      #sensor.set_auto_whitebal(False) # must be turned off for color tracking
          img = sensor.snapshot().binary([BLACK_THRESHOLD])
          if (line):
              rho_err = abs(line.rho())-img.width()/2 #计算一条直线与图像中央的距离
              #坐标变换  xy轴的角度
              if line.theta()>90:
                  theta_err = line.theta()-180
              img.draw_line(line.line(), color = 255)#127
              output_str = "%f"%(theta_err)
              sumA = 0
              sumB = 0
              data = bytearray([0x41,0x43])
              uart.write(data)
              data = bytearray([0x02,8])
              for b in data:
                  sumB = sumB + b
                  sumA = sumA + sumB
              uart.write(data)
              float_value = theta_err
              float_bytes = pack('f', float_value)
              for b in float_bytes:
                  sumB = sumB + b
                  sumA = sumA + sumB
              uart.write(float_bytes)
              float_value = rho_err*0.1
                  sumB = sumB + b
                  sumA = sumA + sumB
              data = bytearray([sumB, sumA])
              uart.write(data)
              print(float_value,theta_err)
              #print(rho_err*0.1)
              sumA = 0
              sumB = 0
              uart.write(data)
              for b in data:
                  sumB = sumB + b
                  sumA = sumA + sumB
              uart.write(data)
              float_value = 200
                  sumB = sumB + b
                  sumA = sumA + sumB
              float_value = 0
                  sumB = sumB + b
                  sumA = sumA + sumB
              uart.write(data)
              #print(theta_err)
              print(float_value)
    • line = img.get_regression([(100,100)], robust = True)
      改为
      line = img.get_regression([(255,255)], robust = True)
    • @kidswong999 但是为什么识别一下卡那不会动半天出来线性回归不是一直动的
    • @g23b robust = True会大大增加运行时间,而且你把图像分辨率调大了,所以运算时间特别长。
      参考这个代码:
      https://book.openmv.cc/example/09-Feature-Detection/linear-regression-fast.html
