  • 请问像是一条线上两种颜色的巡线该如何实现?
      R_THRESHOLD = (59, 25, 127, 19, -128, 89)
      G_THRESHOLD = (0, 100, -69, -32, -47, 82)
      import sensor, image, time,lcd
      from pyb import LED
      import ustruct
      LED(1).on()
      LED(2).on()
      LED(3).on()
      uart = UART(3,115200,bits=8, parity=None, stop=1, timeout_char = 1000)
      sensor.set_vflip(True)
      sensor.set_hmirror(True)
                    # to process a frame sometimes.
      def sending_data(data1,data2):
          global uart;
          data=bytearray([0xA5,data1,data2,0XA6])
          '''data1= ustruct.pack("<bbb",      #格式为俩个字符俩个短整型(2字节)
                         0xA5,                      #帧头
                         data1,
                         data2,
                         0xA6
                         )     '''   #数组大小为7,其中2,3,4,5为有效数据,0,1,6为帧头帧尾
          uart.write(data);   #必须要传入一个字节数组
          #print("head",data[0],"status",data[1],"tail",data[2])
          img = sensor.snapshot().binary([R_THRESHOLD] )
          #img.mean(0)
          #img.midpoint(1, bias=0.5, threshold=True, offset=5, invert=True)
          if (line):
              '''rho_err = abs(line.rho())-img.width()/2
              if line.theta()>90:
                  theta_err = line.theta()-180
              print(rho_err,theta_err)
              if line.magnitude()>8:
                sending_data((int)(rho_err),(int)(theta_err))'''
              rho_err_temp = abs(line.rho())-img.width()/2
              if line.theta()>90:
                  theta_err_temp = line.theta()-180
              print(rho_err_temp,theta_err_temp,line.magnitude())
              pass
          lcd.display(img)
          #print(clock.fps())
    • binary本来就支持多个阈值,阈值数组设置成[(蓝色阈值),(红色阈值)],就完事了。
    • 请问是如何操作呢?直接thresholds = [(颜色阈值),颜色阈值,颜色阈值]的话
      img = sensor.snapshot().binary([THRESHOLDS])
      这里就是报错TypeError: can't convert tuple to int
    • R_THRESHOLD = (59, 25, 127, 19, -128, 89)
      img = sensor.snapshot().binary([R_THRESHOLD, G_THRESHOLD] )
