  • list index out of range?
    • 做交通标志识别出先这个问题,该怎么解决??
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
          # of our objects
              for d in detection_list:
                  [x, y, w, h] = d.rect()
    • colors = [ # Add more colors if you are detecting more than 7 types of classes at once.
      (255, 0, 0),
      ( 0, 255, 0),
      (255, 255, 0),
      ( 0, 0, 255),
      (255, 0, 255),
      ( 0, 255, 255),
      (255, 255, 255),
      多加几行。
