  • 如何把两个滤波效果叠加?比如我想改变对比度同时矫正画面,我依次执行代码时两个功能并没有同时实现
      sensor.set_framesize(sensor.WQXGA2)
          # A clip_limit of < 0 gives you normal adaptive histogram equalization
          # which may result in huge amounts of contrast noise...
          # A clip_limit of 1 does nothing. For best results go slightly higher
          # than 1 like below. The higher you go the closer you get back to
          # standard adaptive histogram equalization with huge contrast swings.
          img = sensor.snapshot().histeq(adaptive=True, clip_limit=3)
          img = sensor.snapshot().gamma_corr(gamma = 1.3, contrast = 1.0, brightness = 0.0)
    • sensor.snapshot()是采集,你重新采集了会覆盖上面的。
      改为:
      img.histeq(adaptive=True, clip_limit=3)
      img.gamma_corr(gamma = 1.3, contrast = 1.0, brightness = 0.0)
