  • 我先用串口帧格式与单片机通讯,在openmv发送数据上出错,为什么说不能把浮点型转整形?我用了int()也不行?
    • #THRESHOLD =(0, 23, -12, 5, -5, 13)
      THRESHOLD_day=(0, 30, -47, 20, -28, 19)
      import sensor, image, time,math,pyb
      from pyb import UART,Pin,Timer
      from pyb import LED
      output_str=''
      uart = UART(3,9600)
      sensor.set_vflip(True)
      sensor.set_hmirror(True)
      sensor.set_windowing((0,60,120,60))
      LED(1).on()
      LED(2).on()
      LED(3).on()
      roi_X=[30,0,30,30]
      roi_stra=[50,0,30,30]
      rho_pid = PID(p=0.7, i=0)
      theta_pid = PID(p=0.3, i=0.5,d=0.1)
           img.draw_rectangle(roi_X, color = (255, 0, 0), thickness = 2, fill = False)
           img.draw_rectangle(roi_stra, color = (255, 0, 0), thickness = 2, fill = False)
           blobs = img.find_blobs([THRESHOLD_day], roi=roi_X,x_stride=1, y_stride=1,pixels_threshold=10)
                  if blob:
                      blobsss = img.find_blobs([THRESHOLD_day],roi=roi_stra,x_stride=1, y_stride=1,pixels_threshold=10)
                              if blob:
                                  print('go!')
                                  output_str =bytearray([0x2C,0x12,128,128,0x5B])
                                  #output_str='&0%d%d*' % (300, 300)
                                  uart.write(output_str)
                                  print(output_str)
                                  pyb.delay(200)
           img = sensor.snapshot().binary([THRESHOLD_day])
           line1 = img.get_regression([(100,100)], robust = True)
           if (line1):
               rho_err = abs(line1.rho())-img.width()/2
               if line1.theta()>90:
                   theta_err = line1.theta()-180
               img.draw_line(line1.line(), color = 127)
               if line1.magnitude()>8:
                  output1=128-output
                  output2=128+output
                  int(output1)
                  int(output2)
                  output_str =bytearray([0x2C,0x12,output1,output2,0x5B])
                  #output_str='&0%d%d*' % (300-output, 300+output)
                  print(output_str)
                  output_str =bytearray([0x2C,0x12,0,128,0x5B])
                  #output_str='&0000300*'
                  print(output_str)
                  pass
